Re: ver 2.5 beta 1 WIN/MAC 64 bit
XTerminator24 wrote:
I flew my first night flight in the A320 tonight and ran into issues with instruments going dark. I'm pretty sure I had all of the lights up as high as they'd go but still no artificial horizon, etc. This flight started in daylight and ended at night. Not sure if that had anything to do with it.
Attached are log and bbox_log
I took some screenshots to demonstrate what I had. If I turned on night vision, the displays were there, they just weren't lit.
http://i.imgur.com/q4Fy7am.png
http://i.imgur.com/M9AJktY.jpg
http://i.imgur.com/HuflqsF.jpg
http://i.imgur.com/Pfy5I1n.jpg
http://i.imgur.com/7GNILjd.jpg
http://i.imgur.com/kaKy3Sn.jpg
Same problem Here
Last night I made a new flight EGLL - EFPD , 34000 ftp . Everything worked out for the best , I've noticed that if I put 1 ( zero does not accept it ) as a cost index , the aircraft follows the profile of climb properly . Only problem , as in theprevious versions, are not read properly STAR ( in this case EGPD airport ) . When selecting ILS for one of the rw shows no STAR available . The AIRAC are regularly updated .
Thanks in advance
this will solved when a330 flightplan module will be implemented to a320. the next step.
I got problems with sound3d. Using 2.5b1 with X-Plane 10.40 64bit on Windows 10.
Loading the game succesfully and loading the plane is ok. But when i switch to the outside view my sim crashes.
Part of my log:
error: Cant find set.ini at=E:\SteamLibrary\steamapps\common\X-Plane 10\Aircraft\Heavy Metal\320neo_JARDesign\plugins\sound3d\set.ini
SoundEngine: data load error. Check .cfg files!
3Dsound Engine by JARDesign v.1.5
Any hints?
Me too..the same error
Part of my log:
Any hints?
Thank you for posting -  nice to know that you are watching.
I continue to notice that sometimes in CLB or DES mode the altitude set in the "window" of the FCU is not respected - it just keeps climbing or descending "on profile".  Has happened on maybe 3 out of 10 flights.   Can't really pin down the conditions when it does it with the time I have available right now.  Maybe above will fix all this.
Best all,
107
Part of my log:
Any hints?
Same problem for me...
108
If you don't mind me asking, what will be solved when the a330 flight plan module is implemented?  The fly-over, fly-by points?
-Thanks.
Ok...I removed the sound3d folder and tested again. Another crash.
Then I tried to remove all the car traffic in x-plane preferences, as suggested in the x-plane developer blog, and magically all seems back to normal...at the moment i'm flying with no problems.
So this issue seems related to a X-Plane 10.40 problem, that probably will be solved in 10.41 next monday.
110
I don't know if anyone else has this report, i have no time to read all 5 pages of answers, but i have noticed that the ND zoom on EFIS panel don't go to 320 nm.
111
Part of my log:
Any hints?
Will fix next beta.
Also will fix little roll bounce
Also some other little bugs.
Sure, no change at flightplan system at this version.
Hipoxya will fix not at 320 but X-Plane 1041.
Next beta will be ready soon, we test it to be compatible with custom soundpack by BSS (sound is great).
Thanks to all pilots for info!!! Thanks a lot!!!!!!!!!
You're welcome Eugeny !
113
Hi ,
First at all, a huge thanks Mister Romanov for all your great improvments
I made several flights and I have  (sure already known) the following remarks :
-when ADIR's aligned, ND display come for me to fast (I don't know how much time in real world)
-is it possible to have for Radio communication up to three decimal points
-for fuel it would be nice to have also up to two or three decimals points (according the flight plan calculations)
-when I made the ENG and APU fire test no illumination lights (on the master warning / caution, engine warning display and the fire/fault light near the eng mode selector
-when alt crz reached, no possibility to come back once switched to the crz pages on the status display lower ecam display
thanks a lot again for all the ameliorations
114
Thanks for the continued support in developing this aircraft. I'll post one last time the most annoying bug I experience with X-Plane 10.40 (but also with older versions): the blank-display that happens suddenly, expecially after the landing procedure started. I'll attach two screenshots, this time the problem appeared after landing, at the moment the cabin crew started talking.
115
http://jardesign.org/forum/viewtopic.php?pid=6613#p6613
follow next beta please
