Re: ver 2.5 beta 1 WIN/MAC 64 bit
Specifically re posts above by XTerminator24 and capbullett. I haven't had the time to test it carefully but I believe I have the exact issue described by Xterminator24 above "Issue 1". After loading the co route without apparent problems when selecting the STAR it says "[dest. airport] deleted from FLT PL". Duplicated this with different city pairs. Most of route then deleted from F-PLN page as described by XTerminator24. This only happens if the first fixes after "SID" in the text file for the company route are also included in the SID read from the nav database (Navigraph 1510). If I make sure that there's no overlap of way points between the database SID and the first way point in the .txt file no problems. I don't have time to test it more than that now. Will investigate more if possible. (10.36 WIN7 64)
And most importantly I agree with the opinion that if you get the managed descent logic fixed and sort the lat nav logic so it will reasonably track (in managed mode) turning SIDs 90% of your customers will jump with joy and not care so much about any of these other things.
