Topic: ver 2.5 beta 1 WIN/MAC 64 bit
First beta, please use it if you really want take part in beta-tests
So, next 320 improvement.
What new:
+Ground Handling Deluxe plugin (not included) compatible
  (mean what now you should have external pwr avail when GPU connected, fuel panel should come  with fueltank, doors shouls open in auto mode)
+FBW “roll” tuned for low airspeed
(based on reports from real pilots tests)
+ready for Custom 3D soundpacks
(not included, expect from 3th part developers like BLYE SKY STAR)
+ND Weather radar range extended
+new SASL base plugin included
Download link http://jardesign.org/a320/download/inst … V2.5b1.zip
  - be sure, what you use X-Plane 10.36 (stable only, not use betas, please)
  - start X-Plane 64 bit and open a320, activation window is show up
This is beta version for X-Plane 10 64 bit. "Beta" mean what some may work wrong.
If your activations are over (activation error) - use contact email from official website http://airbus320neo.com/contact/
Please not discuss things what are not in "whats new" list. Please post your opinion direct here. When you post some, please follow some rules like this http://jardesign.org/forum/viewtopic.php?id=861
Re: ver 2.5 beta 1 WIN/MAC 64 bit
Good job!
After activating tho old problem: crash.
During first flight no problems (with 10.40rc1).
My cruiselevel ist FL370 and no problems to go with normal weight.
Dieter
When the cockpit uptade? Like a dron420?
I dont know, need ask Dron this only smile
Dron, when update cockpit?
When it's ready.
He likes to post preview pics on the Facebook group though, that's the best place to see progress.
Hi everyone,
i'm a real Comercial pilot IFR and Twin Engine Rated, and i've finished the Entry Level Training Course of A320 and i'm aplying for an airline Job in Chile, so i have many points to check about this airplane i'd like to mention for development but i'm not pretty sure if this  is the right thread for that.
Plaese let me know and i'll be happy to help.
Than you all.
You are welcome!
Short feedback (Windows10x64, X-Plane 10.40r1).
-Installed and activated ---- > No problem, great.
-FBW “roll” tuned for low airspeed --> I felt better control of aircraft, nice.
Thanks JAR for update.
Thanks for report!
every time i reload this new beta, the whole sim crashes. It only does it with this beta?
Hi, I found that I am unable to switch to a ND range of 320nm, is this a bug by chance?
Working very good, no crash on Mac using XP10.40r1.
Noticed very stabil behaviour during climb and approach.
Hello, I'm trying  activate but occur a error: "Invalid hardware code!". I'm following the instructions on .txt file, like the others times.
Could you help me with this, please?
ot is normal. 320 NM range not released.
send answer via email!
17 (edited by Acei 2015-09-13 10:16:38)
Flew EGLL to EIDW.  Noticed the following:
- Plane CTD when loaded a couple of times.  It may have been an issue with my download.  Deleted and downloaded again and it seems ok now.
- On loading, there is a crash sound, the FO says Power Set and the CC announcement comes on that normally happens after the doors are shut.  This is before any power is turned on.
- Power set wasn't announced when accelerating for take off
- Only got sound from ADR switches - no sound for any other switches
- Light above Captains side window doesn't work - sorry, didn't check FO's side
Otherwise, there were no issues.
jiggyb2 wrote:
When it's ready.
You are right. Cockpit is still in development.
An ongoing problem is when you enter a flight level into the FMC this generates points which should be defined by just altitude, not position, BUT the FMC generation of these non-existent geographic waypoints, such as (TC) (TD) distorts the course to be flown to the next geographic waypoint. The only way to get a correct course to the next geographic waypoint is to omit the entry of a flight level into the FMC
My first test flight with the A320Neo v2.5beta1 was from KPHL to KATL on the DIRTY approach. FL300 CI 20. Some findings:
- T/C was ± 50 nm off (screenshot)
- ANP was slightly off but still compliant with RNP, no big deal
- Frame rate is fickle; starting off with 40 FPS; near KATL drops to 19 and goes back to 31 for no apparent reason; looking outside into the blue at ALT CRZ I get 160 FPS; with cockpit view the FPS tumbles down to 30
- pitch of nose is a bit hysteric when catching GS or dropping flaps; there's no smooth transition; also when trying to get an altitude restraint, the pitch is weird and not comfy for PAX
- ALT CSTR are not visible in LEGS page or end up with a slightly different number
- not all waypoints are included when choosing the ILS for KATL27R
I'll fly KATL-KMCO tonight. Will let you know.
I notice the flap extension/retraction sounds disappeared.
I found a possible bug in CHECKLIST (Mike).
- BEFORE  TAKEOFF -> when said ENGINE MODE SELECTOR (never stop, loop sound).
p.s
before line up rwy, engine mode selektor was at CRANK positon. I set zo NORMAL, but loop checklist sound (ENGINE MODE SELECTOR, ENGINE MODE SELECTOR, ENGINE MODE SELECTOR...)
I will test again.
that is it for now.
test flight with the A320Neo v2.5beta1 from ESGG to LEPA landing 06 R. FL370-390 CI 18. Some remarks:
- Weather radar at different range Ok very good
- T/C was ± 10-15 nm
-Fuel "door" not closed automatically after the departure from the fuel truck (groundhandling deluxe) (I needed to make it with the standard plugin
-the plane follow not always the flight plan (especially when it turns) difference from +- 5 NM
-Pack 1 and 2 (Air Cond) not automatically shut in auto (on)
-no possibility to add speed constraint into the FMC for the STAR and also for the selected speed
That's all for now
Thanks for your work
thanks for your reports. workon fix
RNAV procedures don't work yet
