Topic: Luggage Loader Belt
Hello, my GHD is working following the installation directions resolves heaps of issues.
I was wondering if the belt loader direction can be changed. Arriving belt moves items toward the bottom of the belt; on departure belts moves as toward the aircraft.
Just wondering.
Re: Luggage Loader Belt
Just wondering.
Please inform what aircraft you tell about and what set you tell about - some default or some custom set for this aircraft?
Hello, I am currently creating a custom set for the IXEG737. The provided belt loader (Loader(B)) seems to be designed for departures, but I would like to change the belt direction for arriving flights.
If there is no way to change the belt direction in the current version, I would appreciate it if you could add a belt loader specifically for arrivals in the next update.
For example:
Anim2: Moving toward the aircraft
Anim3: Moving away from the aircraft
Thank you for your consideration, and I look forward to your response.
