Topic: CoPilot Plugin for ToLiss A340-600
http://jardesign.org/forum/img/m/22/t/p1ggut4s081gt91hfc1rgd17bkrp93.jpg
The work of the pilots in a modern airliner involves two people. You know. Of course, before, the voice of the f.o. pilot was present, but he did not do anything and did not execute commands, did not listen to you, did not live with you. I really wanted this to change and I am happy that my friends supported me in this matter.
So, this is CoPilot plugin for TL340-600 Airliner
REQUIREMENTS:
+ X-Plane 12.00 flight similator
+ Windows OS (7 .. 10) or MAC OS (Sierra .. Catalina)
+ Microphone or Headset
+ ToLiss A340-600 for X-Plane 12 (not included)
+ For voice input Speech Recognition language should be set to English only (for Windows OS)
LANGUAGE: English
DESCRIPTION:
Her name is Linda. She is well-qualified Airbus A340-600 (TM) F.O./copilot. Main Features:
+ animated 3d CoPilot body
+ can recognize and execute your command
+ can speak with you
+ can read checklists
+ can operate with flight events (based on flight parameters detection)
+ can execute SOP (Normal Procedures)
This product is not refundable, but You can download, install and test the demo version (Manual included):
http://www.jardesign.org/copilotdownloa … 091122.zip
Demo mode work up to takeoff phase of the flight. If you like the demo version and you prefer to use the full version - you may purchase serial key here:
SIMMARKET: https://secure.simmarket.com/jardesign- … xp12.phtml
X-PLANE.ORG: coming soon
SUPPORT: www.support.jardesign.org
Re: CoPilot Plugin for ToLiss A340-600
reserved
reserved
4 (edited by godwisper 2022-11-05 10:07:16)
welcome onboard Linda smile
Just bought from sim market but am missing the product key ? If I recall I had one for the A321.
Moreover, I did as per instructions and same like I didon the 321 but keep getting the box to setup and if I reload the aircraft it gives me same option box again.
plugin was updated to version 051122
bug fix
Hey
I just downloaded and bought the add on! Awesome! I just want to thank you for the great product and that it is now available for the Toliss a340. Thanks!
cheers
Nobody wrote:
Hey
cheers
Thank you. We just upload updated version - please use the same link with some logic improvements. You may change only "systems" files.
Hello, I saw the new  Co-Pilot for ToLiss 340-600 and your link to X-Plane.org, so I purchased it and didn't realized that this link is faulty because it is linked to JARDesign-CPL345 CoPilot for JD340-500. XP.org seems not to have your ToLiss A340 on sail at the address you gave us.
As I purchased a faulty version , I would like to get from you a serial number of the ToLiss A346 to my mail: ilankrt@gmail.com.
You can verify  XP.org my order : Order number: 1710008 Order Date: 11/3/2022
Thanks for help
Thanks for help
Hello! This is not a big problem - may activate purchased serial with 346 - this should work (if this serial key was was not activated with any aircraft before).
Thanks for help
WORKING THANKS !
091122 version posted:
+ TARA bug fix
You may change only "systems" folder inside copilot_main
I assigned a SELECT BUTTON on the keyboard, I can change the selection to the command but I can´t activate a command by long pressing....
this thing may work with joystick keys
Hello captains! So this mod won’t work in xp11 anymore?
I also tried it with a joystick button – didn´t work. Could that be fixed? Because trying to hit it with the mouse cursor is not that much fun.
+ TARA bug fix
am getting again this bug
17 (edited by eagleone54321 2023-07-19 00:40:23)
Hello, Eagle One here.
     I saw Co-Pilot for ToLiss 340-600 and your link to X-Plane.org, so( like the guy before me a year or so ago), I purchased it and didn't realized that this link is faulty because it is linked to JARDesign-CPL345 CoPilot for JD340-500. XP.org seems not to have your Co-Pilot for ToLiss A340-600 for sale at the Link you provided.
As I purchased a faulty version, please, kindly provide me with the correct functional serial number for the Co-Pilot for ToLiss A340-600 to my mail: eagleone54321@gmail.com
If you need to Reference my Xplane Store order: Order number: 1825006 Order Date: 07/16/2023
Now, I noted your response to ilankrt back on 2022-11-08 as to a resolution/solution/remedy to said problem but Im not sure i completely understand.  The purchased reg key does not work.  It has never been activated with any other product. I have tried uninstalling and reinstalling but that is goin nowhere.   I have the exact identical issue as ilankrt and am at a loss. Please assist me in doing whatever is necessary to get My Linda next to me in my Toliss A340-600.  I will be more than happy to answer any questions you have.
Thank you in advance.
.... a few hours later.
Well, I went to sim market and bought thier version of C0-Pilot for A346 for another 20 bucks. they gave me a slightly different key.  Same result.  No Linda in sight. I see the drop down, able to register, it accepts key but there is nothin under Commands and no visual on Linda. I am Running Xp11 11.55r. and V1.1.1 of the ToLiss A340-600 Build 1508. What gives?
You may download and install actual version here http://jardesign.org/forum/viewtopic.php?id=18966
It is sad to pay for 2 keys. Sure, you may install and check how it work before pay money. If it work ok, you may register it with serial key from simmarket or dotorg. If you meet troubles, you may just call me via skype j.a.romanov and we will check all things online to make it worked.
Yeah, So I tried everything I know to do. I am still unsuccessful at getting Linda to show up. I also tried to skype you as you suggested. I shall try again to reach you. Thanks
Eagle One    DM
Earlier on, when Toliss A340 Copilot from JarDesign came out, I had given comments that were not right and pretty negative in nature. That was because of not knowing how to use the product and jumping to conclusions. Well, I am sorry and ashamed of what I did. I hope Romanov can forgive me. Now after few months I tried the plugin again, with voice commands enabled and following the correct sequence of Procedures and Checklists, I find it to be the best copilot available in pay and freewares as well.
Please keep up the good work.
