Topic: PFETOXPLANE + Copilot on XP12 - on screen menu not usable
I’m using PFETOXPLANE together with JD Copilot on XP11 for a while.
Now I’m switched to XP12. As soon as I enable the PFETOXPLANE plugin, the on-screen menu of JD Copilot can not be used anymore. All mouse actions are ignored.
Is this a known issue? Is there anything I can do to make it work again?
Jens
Re: PFETOXPLANE + Copilot on XP12 - on screen menu not usable
Seems like it's some sort of special issue. Sure, you can contact me via skype j.a.romanov for direct help - we will check this issue online. You may call anytime when my skype label is green.
