Topic: Ground Handling Deluxe error
Hi I installed the
Ground Handling Deluxe but when I go on my a330 I get a red writing that tells me that I have not installed but the beauty and that there is and what can be? Thank you
https://imageshack.com/a/img923/2909/oaeiom.png
Re: Ground Handling Deluxe error
i have the same problem. Did you get it to work and if you do. How did you fix it?
please contact support directly via skype j.a.romanov - will check this issue on your side.
