Topic: GHD deluxe causes xp-12 to CTD with certain aircrafts.
I have a registered version of GHD deluxe. When the plugin is installed in XP-12 it crashes to desktop when i try to load certain aircrafts.
So far it happens with SSG 747, FF A350 XWB and every plane that doesn't use GHD.
Every aircraft is up to date.
Please can you solve this ???
Re: GHD deluxe causes xp-12 to CTD with certain aircrafts.
Please be sure you use XP12 version of GHD. If still the same - please use www.support.jardesign.org and attach Log.txt file to the ticket just after crash happen - I will check and inform you.
