Topic: Linda wants to set different trim value
With Toliss 319 in XP 12, I calculate weight and balance /zero fuel weight/center of gravitatie in the SCSI window …then copy the values calculated in the SCSI into the MCDU…and when I have set the trim manually to for example 1.7 up,just before take off Linda
will advise  me , that trim value is not correct for take off and then flings the trim-wheel in a much too high setting.What goes wrong here?
Re: Linda wants to set different trim value
I have the same issue. Not sure if it is always the same value. I needed UP0.4, but Linda thought it was supposed to be DN0.3.
