I experience a crash of X-Plane, whenever I ask for a different runway to start from.
Any suggestions on how to solve this problem?
Greetings, Fishman
JARDesign Group Board → Updates & General Discussion → X-Life version v4 for X-Plane 11.50
Greetings, Fishman
Please be sure you use updated version http://jardesign.org/forum/viewtopic.php?id=11819
If this happen with actual version - please send Log.txt file (from root X-Plane folder) to www.support.jardesign.org
- I will check and inform you.
I have only one problem so far with version 4.30 deluxe and xplane 11.55.
I can no longer access "airport editor" to modify the airport I am on, I can only create a new airport.
what is the reason?
what is the reason?
Last version where Editor is work was 11.41
This is only way.
Hello. Will there be "Vulkan" driver support?
As for now - not support. About future versions - will see how XP12 will going. Don't know right now.
Im trying to install x life but the freeware one not deluxe, I downloaded it and then installed the unzipped "x life" folder into plugins and when I loaded it it asked for a serial number or registration thing? I dont know where to get that and why does the freeware version have that?
hmm.. it should not. You may contact me via Skype j.a.romanov - will check this issue online.
I wont be able to skype for the next 2 weeks but I will definitely give you a call if the issue persists
Will the present version ( v4.30 260522 ) of X-Life work in X-Plane 12 or will it require an update
It will be updated, but exist version may work too
Hi there, just got x life freeware. Im flying in Australia and i tried using the x life flight plan thing but it said the airport wasnt supported that i was flying to but online it says Adelaide is supported?
Anyway I would like to know if theres any way of adding support to airports in Australia either by downloading or attemp to do it myself. I tried checking if you can do it online but I havent had a clear answer yet could someone maybe explain to me how to do it if its possible?
Hello Jar, I tried X-Life and Ground Handling in XP 12 and neither work, so it appears both need an update. Both were loaded as per XP11.
For your information.
Hello! GHD already get updated version - please download it from this board and try
Hello Jar, thanks for the reply. I've now got GHD working, tried again with X-Life, still not working in XP12.
Hopefully an update will sort it out as I think it works really well.
What happen wrong with X-Life - you can not get it started? Or?
Hello Jar, as soon as X-Life is started in XP12 a splash screen appears stating, Deprecated dataref use by X-Life/win.xpl sim/weather/use_real_weather_bool
The author should update this to ensure future compatability. This probably means more to you than it does to me.
The start panel is very grey in colour, but appears to work. When it starts it shows the wrong airac, 2010, when the current is 2009. The current airac is loaded into XP12 via Navigraph.
When trying to load a flight plan X-Life doesn't recognise waypoints, it seems to recognise airways, even when I ask X-Life to make a flight plan.
I did say GHD for X-Plane 12 was working but when I tried the start up screen appears, the selected services do not drive up when the drive up button is clicked.
The author should update this to ensure future compatability. This probably means more to you than it does to me.The start panel is very grey in colour, but appears to work. When it starts it shows the wrong airac, 2010, when the current is 2009. The current airac is loaded into XP12 via Navigraph.
When trying to load a flight plan X-Life doesn't recognise waypoints, it seems to recognise airways, even when I ask X-Life to make a flight plan.I did say GHD for X-Plane 12 was working but when I tried the start up screen appears, the selected services do not drive up when the drive up button is clicked.
Thanks for this info about X-Life. Sure, we still not build XP12 version. About GHD - are you talk about XP12 version of GHD? If so - please contact me directly via skype j.a.romanov - we will check this issue online.
Hello Jar, I only have two added aircraft for XP12, the Toliss A319 and the A321, GHD works correctly on the A319. On the A321 the setup panel appears, I then click on the support vehicles and click drive up on the panel and no support vehicles drive up.
GHD doesn't seem to recognise the Toliss A321.
I do have the XP12 of GHD. So, the A319 works correctly, the A321 doesn't work.
I have tried X-Life again, I updated the Navigraph latest AIRAC to XP12, but the AIRAC didn't appear when X-Life started, so when I tried to load a flight plan it was not accepted by X-Life. I tried to get X-Life to generate a flight plan and the plan made no sense.
Hope this helps.
Hello Jar, further to my last post both the Toliss airbusses are the XP12 updated versions, the A319 is v1.7.1 and the A321 is v1.4.1.
Hello Jar, I downloaded GHD again and installed it and it's now working on both the Toliss airbusses.
Great! Thanks for this info!
Hello Jar, you may have answered this question, but are you working to update X-Life for XP12, the ATC in XP12 really doesn't work well and for those not interested in Vatsim or Pilot Edge X-Life is the way to go.
what is the reason?
Hi Blackcat,
a had the same issue with the Airport-Editor and I found a simple workaround for XP11.50+
Just uncheck the Vulcan option in the graphic settings and restart X-Plane. Then try again to open the Airport-Editor. With the old graphic engine the editor works fine with newer X-Plane versions.
Hope this help you too.
Airport Editor may work with XP11.41
For later XP versions LR just cut out ability to use functions what needed for editor. I dont know why - you may guess.
