Topic: SSG 748-F widget close immediately
on the latest SSG 2.4-2.5 the widget on the freighter version close itself as soon you try to open. I checked logs but i don't see any error.
On the passenger version the widget opens normally.
Can you help me?
Re: SSG 748-F widget close immediately
Common reason for this (for any aircraft) - trying to call Handling with Parking Brake off. Please check this first.
thanks for the tip, i found out that when the plane starts the chocks are on, when the chocks are on you can't enable parking brake, so if i remove the chocks and quickly open GHD the parking brake sets automatically and now i can use the plugin.
I hope it will help other people using freighter version
