1 2022-04-01 11:49:56 (edited by DouiTz 2022-04-01 11:51:40)
Re: After takeoff Problem
I always meet this issue when the plane is climbing, just after my plane takes off.
Before takeoff, I press the T.O CONFIG button and my ECAM doesn't show these warnings.
Anyone got in same situation?
You may call me via Skype j.a.romanov - to make test flight together and check what may going wrong.
Problem solved.
The problem only occurs when I set the flex temp to F40, rather than system calculated temp.
