Topic: Copilot Rotate MD80
Hi a little request for your fantastic copilot plugin for the rotate md80
i was hoping that you at least would take this suggestion up to consideration smile
Best regards David
Re: Copilot Rotate MD80
Best regards David
This depend mostly of Rotate, cause initially - need to make some simple preparations in aircraft. This may be done by aircraft developers only. So, only way - push rotate for this first smile
