Topic: wrong course set by copilot
Why there is always some degree of difference between the course set by copilot and the data on navdata (updated)?
i.e.: on FMC ILS runway set shows the frequency and course to be set, it is the same of the chart i have, when copilot set course it is some degree more (or less)
Re: wrong course set by copilot
I get that same issue as well, she turns by ONE degree. I manually adjust it on her side as a workaround.
You are right. I think (I heard a long time ago) it has something to do with the charts that has been used (real life charts, XP, Simbrief, Navigraph) and is not CoPilot Linda or Zibo related . They sometimes differ a little bit. Like you wrote, it can easily be changed. So I don't worry about that.
Win 10, XP11
Is this difference less 1 deg, or more?
5 (edited by gintonic 2022-01-01 17:34:04)
Is often 1 degree.
The strange thing i don't understand is where copilot retrieve this data because i have all navdata aligned through navigraph.
i.e. LIRN ILS P RWY24 charts state course 235° and copilot set at 234°
Is often 1 degree.
this is math rounded issue in the plugin - sometime it rounded down.
