Topic: Control Widget not showing up - X-Plane 11 / Win10
Hi all,
just installed GHD on X-Plane 11 under Win10. Plugin is working fine except that the Control Widget in not showing up from the Plugin menu (X-Plane Menu->Plugins->GroundHandling->Show Control Widget)... I can show/hide vehicles using the other options from the scroll down menu under the "Control" option, but I cannot display the Control Widget window itself.
Any idea?
Thanks,
Lins
Re: Control Widget not showing up - X-Plane 11 / Win10
Please be sure what you install more fresh version from http://jardesign.org/forum/viewtopic.php?id=11820
If no luck - Seems like it's some sort of special issue. Sure, you can contact me via skype j.a.romanov for direct help - we will check this issue online. You may call anytime when my skype label is green.
