Re: GHD v4 for X-Plane 11
hello, I bought this plugin in the x plane store, it said that it works with all versions, I did everything according to the instructions, but it does not see the planes purchased there, what should I do? The equipment just stands from behind and that's it, and there is no picture with an airplane in the menu! Help!
Thanks for the latest update for the ToLiss. Unfortunately it's still not fully compatible with the Airbus SOPs. A problem is that it's hardwired that all vehicles drive away once the parking brake is released. According to Airbus preflight check SOP the parking brake must be temporarily released to test the alternate braking system. And gone is ground handling...
So I highly suggest that the trigger for automatic drive away is configurable, e.g. parking brake/beacon/none. GUI, config file, dataref, everything is acceptable.
GndHandling:OAL_error(480)=No such error code
Since installing the fix for toliss A319 1.6.2, I am now seeing the above error code for Toliss A321.
Anyone else experiencing this continuous error?  Had to disable the GHD plugin to stop the performance drain.
Updated/hotfix was already published
http://jardesign.org/forum/viewtopic.ph … 291#p32291
30
Hi Evgeny,
I am unable to install the new version of Ground Handling
I don't found my key
I probably lost it (a very old one)
I7- 7700  3.6 Ghz    ASUS B250 h Gaming  Dimm 64 b.    8GB ddr4 Kingston 2400
GeForce 1060 3Gb ,   DDR Kingston 223 Gb   HD 7200 t/m 931 Gb
farcher wrote:
Hi Evgeny,
Please contact www.support.jardesign.org with info:
What shop was used? Where you get product, please? Also, please inform me what Date was and what Email was used for purchase? Do you have Order ID? Are you already trying to login this shop and see your data?
Hi Evgeny,
I GHD no longer works. I can see it in the plugins pull down menu in X-Plane, but when I choose one of the GroundHandling menu options (e.g. Drive up all) nothing happens.
I redownloaded the GHDxp1150 version and reinstalled GHD, but without result.
ronald wrote:
Hi Evgeny,
You may call me skype j.a.romanov - we will check this issue online.
Excuse me but I need your help I have a problem with GHD. It is working perfectly well with my X craft family embraer but not at all with my A 320 ULTIMATE with X plane 11.I do not understand. GHD works perfectly well with Xplane 12 and the A
May be you need just visit our http://simliveries.com/index.php/category/ghd-set... to check what aircraft(s) have compatible sets to work well with GHD. Next you can download .set file and put it to ../X-Plane/Resources/plugins/GndHandling/Sets/Custom/ folder.
If no set there for your aircaft, another way may be used. Open ../X-Plane/Resources/plugins/GndHandling/Sets/Default/ folder and find .set file what may be good for your aircraft by name. Take this file and put it to your aircraft folder, close to .acf file. Next - rename .set file with the same name what used for .acf file. So, if you see b737.acf file you should rename set like b737.set This trick will allow you to try to use any of exist set with any aircraft you want.
36
Discover the ultimate in relaxed romance with the best casual dating platform!
Looking for a partner for unforgettable moments?
Verified Ladies
Superlative casual Dating
