Re: XP11.50 JD330 v.4.3
I am sorry that I have come back with a request and have to ask for help.
An A330 file was probably damaged by some kind of action. The ND popup window is only very, very small (2x2 cm), so it is illegible.
Question: Can I replace this file (from the backup)? And if so, which file is it?
Thank you for your feedback and sorry.
dhondt
dhondt
You may just delete widgets.txt file from /plugins/fmgs/   folder before you load aircraft to reset all widgets settings to default.
53
Super. Thanks for the quick help.
