1 (edited by pepolk0001 2021-08-11 13:54:49)
Topic: jar340 and TCH Throttles
Does the jar340 not support individual movement of the power levers?
Using my Thrustmaster Airbus quadrant, right now I am only able to set power with power lever #1 (it controls all four power levers in the aircraft). Levers 3-4 on my quadrant do nothing, even though they are mapped correctly (default) in xPlane 11). It feels a bit like flying a c172 right now since all the power levers in the simulation move together with one power lever on my quadrant.
Did a fresh install of Xplane 11 and then loaded up the jar 340 and same issue.
Re: jar340 and TCH Throttles
Did you adjust the throttle Axis Settings in the MCDU Settings Menu?
Thank god it was operator error. Yes that worked, thanks!
I just found this after submitting a report in the support forum.
Same operator error wityh CHproducts throttle quadrant ;-|
My throttle can't be in the CLB position while the TCA quardent is in the CLB position, and the FLEX can't be in the right position. Hope someone can help me with this problem
