Topic: Linda s Image
Hello. I bought the copilot for the zibo 737 today. i have linda's voice but no picture.
can you help me please?
JARDesign Group Board → CoPilot for Zibo737 → Linda s Image
For me same problem ...Linda is talking to me but not showing in the copilot seat...not after activation ....not after I have reinstalled all Windows redistributables....can you help?
If no 3D object exist after you click on SETUP button and reload aircraft - please check what your Zibo 737 is really actual, cause old 737 versions not include copilot 3D object.
Ah thanks for yr reply Eugeny ...I loaded latest ZIBO 737 and now copllot Linda is visible.....next issue:Siselkov raindrops are in between me and Lindas face when using librain.Any solution for that?
May be this depend of some object properties, but this may be fixed on Zibo side, I can not change any in .acf
Is rain work with vulcan on 11.50?
ive valued your products and now have linda copilot, i do so hope linda is going to be remodelled without her walkout tunic to reflect in cabin attire, her repitive movements to the same location, ie arm up arm down arm up etc etc will be worked on and a number of other modifications listed by others are addressed. be such a shame if not. the principle is most effective.
I recently purchased Copilot B737 ZIBO MOD.
Everything works perfectly but the copilot (F or M) does not appear even though it is present in the A320.
Which solution ?
I see the forum; what is the latest version B737-800 ZIBO mod who works with it ?
Is there a problème with LibRain B737-800 ZIBO mod ?
Thank you in advance for the expected response
OK i'ts good. I had not the last update for B737-800X zibomod
mermoz
i am dissappointed no acknowledgment to my comments, am I to assume no improvements are likely?
Moragonm1 wrote:ive valued your products and now have linda copilot, i do so hope linda is going to be remodelled without her walkout tunic to reflect in cabin attire, her repitive movements to the same location, ie arm up arm down arm up etc etc will be worked on and a number of other modifications listed by others are addressed. be such a shame if not. the principle is most effective.
I had hoped not to write this believing that one of my plugins might be the cause. I and a number of users are are having ALT DISAGREE issues. ive spent days on end even loading a Vanilla zibo with latest 18 release, removed all my plugins and adding them one by one. Linda appears to be the culprit even though not everyone is having the issue. take out Linda and my altitudes match in both the captains and co pilots PRIMARY DISPLAY throughout the flight, put her back and we are back to ALT DISAGREE. what is also interesting is that my ATC CLIENT SOFTWARE reads the altitude from the co pilots primary display and not the captains. i and others im sure would appreciate to have this issue investigated. for the time being i will have to keep Linda co pilot uninstalled.
I tried the demo version of CoPilot without any issues. I liked the plugin so purchased a license on XPlane.org.
Everything on my computer has now gone haywire!
As soon as I did that it would not take the license. I tried several times and it crashed Xplane to the desktop.
Rebooted and loaded Zibo up again. Got the license installed but it caused Xplane to crash to desktop again.
I then loaded up another plane and everything worked perfectly. Tried Zibo again and it crashed to desktop.
Then removed the two CoPilot folders from the Zibo plugin folder and Zibo and xplane loaded up fine with one exception.
Attached is a screenshot of what I believe is the back of Linda's head. I cannot get rid of it. It stays in that position contantly!!!!!!!!!!!
Now I am getting "Xplane has no memory" and a crash to desktop. Remove the Copilot folders and it loads up fine but with the back of the head in my windshield. This did not happen initially but it is now chronic.
Please let me know how I can fix this problem. I would love to use Linda but if that does not work, I would like to fly my Zibo without the back of head in the windshield.
