EICK is updated
JARDesign Group Board → Updates & General Discussion → X-Life version v4 for X-Plane 11.50
EICK is updated
When I enable X-Life (beta version, with X-Plane Vulcan beta), I get many error messages.
They are all about errors loading the scenery file (for planes), and says they may look incorrect.
(It's annoying because the message keeps coming up for every possible plane. But from what I've seen, they look normal to me.)
Two good airports by tdg, LIBR Brindisi and LFLB Chambery could they be included in the X-Life airport list.
Hello I tried a320 jardesign, xlife 4.20 ATC with vulkan 11.50b10 with my oculus rift s in VR. without xlife activate the FPS are upper 40 , but when I started xlife ATC the fps down under 20 fps (it took 30% ressources !!). it's only ATC that do this. the traffic took only 3% of ressources.
maybe there an amelioration for ATC.
Hi There,
Firstly a fab product. I downloaded the latest MAC version.
I have now updated NAV data using FMS data manager. The new data in in my Custom Data folder. See attached screenshot.
X-plane loads and FMS on the Cessna 172 seems up to date with cycle 2006 Rev 1. I checked the status on a Boeing 737 FMS and it showed current cycle.
However, when I start x-life it says cycle 1210 is loaded.
So, an idiot question, how do I point x-life to the updated data?
Paul
OK sorted. Found the correct add-on and created the FMS430 folder.
Hi There,
Paul
Two solutions :
1- You create a folder "GNS430" inside x-plane 11/custom data … and you install in it the last "Navdata" folder found on manual download page at the bottom of the page :
X-Plane GNS430, FF757/767/777, X-Crafts Embraer E-175, Aerobask SkyView, JRollon Planes CRJ200, JARDesign A320/A330, ToLiss A319 (XP10), STMA Aircraft, Magknight 787AE - native**
2- You install manually the Navdata folder directly into "X-plane11/ressources/plugins/X-life " folder to replace the existing one (whith 1210 cycle)
a 3rd possibility is to give FMS data manager , the right way to get an automatic update :
or X-plane11/ressources/plugins/X-life/Navdata (to be verified) .
Happy flights
Error message every time X-Life starts up? See error log below:
XL: 112 : !!! MakeAtsRadiusPointsListThread
XL: 117 : X-Life:Curl (CurlUpdateSheduler) = EDDT
XL: 117 : JARDesign plugin: E:\Steam\steamapps\common\X-Plane 11\Resources\plugins\X-Life\Metar/EDDT.TXT file updated.
XL: 117 : Autogen flight: pc12
XL: 117 : Autogen flight: b737-300 america_west
0:05:42.141 E/SYS: MACIBM_alert: Error loading the scenery file:
0:05:42.141 E/SYS: MACIBM_alert: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-300/anim.obj
0:05:42.141 E/SYS: MACIBM_alert: The scenery may not look correct.
0:05:42.141 E/SYS: MACIBM_alert: Please see the Log.txt file for detailed error information.
0:05:42.141 E/SYS: MACIBM_alert: C:/jenkins/design-triggered/source_code/app/X-Plane-f/../../engine/OBJ/OBJ_read.cpp:703
0:05:42.141 E/SYS: +-------------------------------------------------------------------------------
0:05:42.141 E/SYS: | Error loading the scenery file:
0:05:42.141 E/SYS: | E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-300/anim.obj
0:05:42.141 E/SYS: | The scenery may not look correct.
0:05:42.141 E/SYS: | Please see the Log.txt file for detailed error information.
0:05:42.141 E/SYS: | (OBJ_read.cpp:703)
0:05:42.141 I/OVR: User is entering the holodeck.
0:05:42.141 E/SCN: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-300/anim.obj:17:
0:05:42.141 E/SCN: LIGHTS 0 2 is out of range; OBJ file is bad.
0:05:45.443 I/OVR: User is leaving the holodeck.
XL: 117 : Autogen flight: a330 us_airways
0:05:45.464 E/SYS: MACIBM_alert: Error loading the scenery file:
0:05:45.464 E/SYS: MACIBM_alert: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a330/anim.obj
0:05:45.464 E/SYS: MACIBM_alert: The scenery may not look correct.
0:05:45.464 E/SYS: MACIBM_alert: Please see the Log.txt file for detailed error information.
0:05:45.464 E/SYS: MACIBM_alert: C:/jenkins/design-triggered/source_code/app/X-Plane-f/../../engine/OBJ/OBJ_read.cpp:703
0:05:45.464 E/SYS: +-------------------------------------------------------------------------------
0:05:45.464 E/SYS: | Error loading the scenery file:
0:05:45.464 E/SYS: | E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a330/anim.obj
0:05:45.464 E/SYS: | The scenery may not look correct.
0:05:45.464 E/SYS: | Please see the Log.txt file for detailed error information.
0:05:45.464 E/SYS: | (OBJ_read.cpp:703)
0:05:45.464 I/OVR: User is entering the holodeck.
0:05:45.464 E/SCN: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a330/anim.obj:16:
0:05:45.464 E/SCN: LIGHTS 0 2 is out of range; OBJ file is bad.
0:05:46.564 I/OVR: User is leaving the holodeck.
XL: 117 : Autogen flight: a320 canadian
0:05:46.582 E/SYS: MACIBM_alert: Error loading the scenery file:
0:05:46.582 E/SYS: MACIBM_alert: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a320/anim.obj
0:05:46.582 E/SYS: MACIBM_alert: The scenery may not look correct.
0:05:46.582 E/SYS: MACIBM_alert: Please see the Log.txt file for detailed error information.
0:05:46.582 E/SYS: MACIBM_alert: C:/jenkins/design-triggered/source_code/app/X-Plane-f/../../engine/OBJ/OBJ_read.cpp:703
0:05:46.582 E/SYS: +-------------------------------------------------------------------------------
0:05:46.582 E/SYS: | Error loading the scenery file:
0:05:46.582 E/SYS: | E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a320/anim.obj
0:05:46.582 E/SYS: | The scenery may not look correct.
0:05:46.582 E/SYS: | Please see the Log.txt file for detailed error information.
0:05:46.582 E/SYS: | (OBJ_read.cpp:703)
0:05:46.582 I/OVR: User is entering the holodeck.
0:05:46.582 E/SCN: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a320/anim.obj:16:
0:05:46.582 E/SCN: LIGHTS 0 2 is out of range; OBJ file is bad.
0:05:47.430 I/OVR: User is leaving the holodeck.
XL: 117 : Autogen flight: b737-700 united
0:05:47.449 E/SYS: MACIBM_alert: Error loading the scenery file:
0:05:47.449 E/SYS: MACIBM_alert: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-700/anim.obj
0:05:47.449 E/SYS: MACIBM_alert: The scenery may not look correct.
0:05:47.449 E/SYS: MACIBM_alert: Please see the Log.txt file for detailed error information.
0:05:47.449 E/SYS: MACIBM_alert: C:/jenkins/design-triggered/source_code/app/X-Plane-f/../../engine/OBJ/OBJ_read.cpp:703
0:05:47.449 E/SYS: +-------------------------------------------------------------------------------
0:05:47.449 E/SYS: | Error loading the scenery file:
0:05:47.449 E/SYS: | E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-700/anim.obj
0:05:47.449 E/SYS: | The scenery may not look correct.
0:05:47.449 E/SYS: | Please see the Log.txt file for detailed error information.
0:05:47.449 E/SYS: | (OBJ_read.cpp:703)
0:05:47.449 I/OVR: User is entering the holodeck.
0:05:47.449 E/SCN: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-700/anim.obj:13:
0:05:47.449 E/SCN: LIGHTS 0 2 is out of range; OBJ file is bad.
0:05:48.474 I/OVR: User is leaving the holodeck.
XL: 117 : Autogen flight: b737-700 air_berlin
XL: 117 : Autogen flight: b737-700 sunexpress
XL: 117 : Autogen flight: b767-300er air_canada
XL: 117 : Autogen flight: b737-800 hapag_lloyd
0:05:49.012 E/SYS: MACIBM_alert: Error loading the scenery file:
0:05:49.012 E/SYS: MACIBM_alert: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-800/anim.obj
0:05:49.012 E/SYS: MACIBM_alert: The scenery may not look correct.
0:05:49.012 E/SYS: MACIBM_alert: Please see the Log.txt file for detailed error information.
0:05:49.012 E/SYS: MACIBM_alert: C:/jenkins/design-triggered/source_code/app/X-Plane-f/../../engine/OBJ/OBJ_read.cpp:703
0:05:49.012 E/SYS: +-------------------------------------------------------------------------------
0:05:49.012 E/SYS: | Error loading the scenery file:
0:05:49.012 E/SYS: | E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-800/anim.obj
0:05:49.012 E/SYS: | The scenery may not look correct.
0:05:49.012 E/SYS: | Please see the Log.txt file for detailed error information.
0:05:49.012 E/SYS: | (OBJ_read.cpp:703)
0:05:49.012 I/OVR: User is entering the holodeck.
0:05:49.012 E/SCN: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/b737-800/anim.obj:13:
0:05:49.012 E/SCN: LIGHTS 0 2 is out of range; OBJ file is bad.
0:05:50.437 I/OVR: User is leaving the holodeck.
XL: 117 : Autogen flight: b737-800 air_berlin
XL: 117 : Autogen flight: b737-700 air_canada
XL: 117 : Autogen flight: b737-700 privatair
XL: 117 : Autogen flight: a319 united
0:05:51.024 E/SYS: MACIBM_alert: Error loading the scenery file:
0:05:51.024 E/SYS: MACIBM_alert: E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a319/anim.obj
0:05:51.024 E/SYS: MACIBM_alert: The scenery may not look correct.
0:05:51.024 E/SYS: MACIBM_alert: Please see the Log.txt file for detailed error information.
0:05:51.024 E/SYS: MACIBM_alert: C:/jenkins/design-triggered/source_code/app/X-Plane-f/../../engine/OBJ/OBJ_read.cpp:703
0:05:51.024 E/SYS: +-------------------------------------------------------------------------------
0:05:51.024 E/SYS: | Error loading the scenery file:
0:05:51.024 E/SYS: | E:\Steam/steamapps/common/X-Plane 11/Resources/plugins/X-Life/Aircrafts/OSX_anim/a319/anim.obj
0:05:51.024 E/SYS: | The scenery may not look correct.
0:05:51.024 E/SYS: | Please see the Log.txt file for detailed error information.
0:05:51.024 E/SYS: | (OBJ_read.cpp:703)
Is it possible f.e. for SFD EDDM to detect bridges for taxiways and dont let the aircraft sink down unter the bridges ?
This kills the complete immersion watching the aircrafts at airports with bridges over streets
Interesting..I can hear the aircraft engines around me, but I don't see any airplane..they use a stealth mod? Any advice? De-Luxe version..
w w w. buyrealdocuments.cc - We produce real database documents and register all the client's information in the supposed database system. This real documents shall pass all airport scans and other data reading machines. When ever this real document is checked, all the client's information will show up in the supposed database system. For Example, if you want us to order a Canadian Passport, we'll register all your biometric information in the Canadian central database system under the government recognition. So your new document will pass airport scans and checks and you will legally use the document without any problems.
We work directly with government representatives to deliver a fast & secure process of acquiring your new passport. Depending on the country you choose, acquiring second citizenship is an expensive procedure, and requires a high-level of trust from the perspective of both the client and the agent. Each year more and more frustrated business people whose passport restricts their commercial opportunities turn to Real Documents company for their long-respected expertise and hands-on assistance in achieving their dream to get the new passport and travel freedom.
To get the additional information and place the order just visit our website:
w w w. buyrealdocuments.cc w w w. buyrealdocuments.cc
Keywords:
Buy US Passport for sale online
Buy USA Passport Online
Buying a passport online
Comprar pasaporte de Estados Unidos en linea
Documents for sale
fake passport for sale
Genuine Document online
I.D cards for sale
Passport For Sale
passport online
real british passport for sale
real british passport online
Real passport for sale
Registered and Unregistered British Passport online
uk passport for sale
UK Passport zum Verkauf
United States Passport for sale.
Buy passport online
Registered second passport
Valid passport Buy Fake Passport
buy passport
buy passport online
fake passport Passports for Sale
Buy Fake Passport online
Buy fake and Real Passport Online
buy legal passport online
Real Passport for Sale
Buy Diplomatic passport
buy second passport
German Passport for sale
Buy German Passport
Deutch Passports for Sale
Buy drivers license online
Real drivers license for sale
buy I.D cards online
Driving license for sale
Buy real France I.D Card
Get Real uk license British ID Cards
real ID Real driver's licence
novelty documents uk
Buy SSN Online
buy Social Security Number
buy USA driving lisense online
Buy CA fake license
real I.D cards online
Acheter des passeport de faux
Belges Nouveaux passeports
Acheter le Faux Passeport Belge
Acheter un permis de conduire
belge Achetez Reel passeport de la Belgique
Belges Faux permis de conduire Belgique a vendre
Belgian Fake Passport id
Belgique ID a vendre
Belgium Fake Passport for Sale
Belgium IDs For Sale
Buy Belgian driver’s license online
Buy Belgian driving license
Buy Belgian Fake Drivers License
Buy Belgian Fake ID Cards
Buy Belgian Novelty Passports
Buy Belgian Passport
Buy Belgian real registered passport
Buy Belgium Fake Drivers License
Buy Belgium Fake Passports
Buy European ID Card
Buy Fake Belgian ID card
Buy False Belgian ID card
buy Novelty Documents Belgium
Buy Real Belgian ID Cards
Buy Real Belgium Passport
Fake Belgian ID
Fake Belgian Passport Sale
Fake Belgium passport
Fake ID
Fake ID Buy Belgium
Faux Belgique Carte D’identite
How To Make Belgium
je Belgie valse ID
Koop Belgie Valse ID
Koop Belgische valse Rijbewijs
Koop echte Belgische identiteitskaarten
Koop een Europese identiteitskaart
Koop valse Belgische identiteitskaart
Koop valse Belgische identiteitskaart Echte
Belgische identiteitskaart Hoe maak
Novelty Belgian passports
Novelty Belgium drivers licence
Real Belgium ID card
Australia IDs For Sale
Australia Novelty Documents
Australian Fake Passport for Sale
Australian Novelty Passports For Sale
Buy Aussie Fake Passports
Buy Australia Real registered Passport
Buy Australian Fake Drivers License
Buy Australian Fake ID
Buy Australian Fake ID Cards
Buy Australian passport
Buy Australian real passport
Buy fake Australian driver’s licence
Buy Fake Australian Drivers License
Buy Fake Australian ID Card
Buy False Australia ID card
Buy Novelty ID card
Buy Real Australian ID Cards
Buy Real Australian passport
Fake Australian ID
Fake Australian passport
Fake Australian Passport Sale
Fake Passport id
How To Make Australian Fake ID
Novelty Australian drivers license
Real Australian ID card for sale
Buy Fake Driving License
Buy Fake Spain Drivers License
Buy Fake Spain driving license
Buy Fake Spanish driver’s licence
Buy Fake Spanish driving license
Buy Fake Spanish driving license online
Buy False Spain driver’s license
Buy Novelty Spain driving license
Buy Real Spain ID Card
Buy Real Spanish driver license
Buy real Spanish driver’s licence
Buy Spain driver license online
Buy Spanish driver license
Buy Spanish Fake drivers licence
Buy Spanish Fake Drivers License
Buy Spanish Passport online
European Union
Fake Spain drivers license Sale
Fake Spanish passport
How to create fake driver license
How To Make Fake Spanish driver license
Novelty Documents Spain
Real Spanish Drivers Licence
Real Spanish ID
Spanish fake driving license for sale
Spanish Fake Passport id
Spanish IDs For Sale
Spanish Novelty drivers license For Sale
Buy Dutch driver license
Buy Dutch Fake drivers licence
Buy Dutch Fake Drivers License
Buy Dutch Passport online
Buy Fake Dutch driver’s licence
Buy Fake Dutch driving license
Buy Fake Dutch driving license online
Buy Fake Netherlands Drivers License
Buy Fake Netherlands driving license
Buy False Netherlands driver’s license
Buy Netherlands driver license online
Buy Novelty Netherlands driving license
Buy Real Dutch driver license
Buy real Dutch driver’s licence
Buy Real Netherlands ID Card
Dutch fake driving license for sale
Dutch Fake Passport id
Dutch IDs For Sale
Dutch Novelty drivers license For Sale
Fake Driving License Europe
Fake Dutch passport
Fake Netherlands drivers license Sale
How To Make Fake Dutch driver license
Novelty Documents Netherlands
Real Dutch Drivers Licence
Real Dutch ID online
Belgian fake driving license for sale
Belgian IDs For Sale
Belgian Novelty drivers license For Sale
Buy Belgian driver license
Buy Belgian Fake drivers licence
Get original driving license Portuguese (Portugal)
Get original driving license Hungarian (Hungary)
Get original Mexican driver's license (Mexico)
Get original Belgian driving licenses (Belgium)
Get original driving license Greek (Greece)
Get original driving license Romanian (Romania)
Get original driving license Lithuanian (Lithuania)
Get original driving license Polish (Poland)
Get original driving license Bulgarian (Bulgaria)
Get original Australian driver's license (Australian)
Get original Canadian driver's license (Canada)
Get original French driving license (France)
Get original German driving license (Germany)
Get original UK driving license (United Kingdom)
Get original international drivers license
I use X-plane last beta and bought x-life deluxe beta. In my x-life deluxe all atc buttons on top is not active and freq window is blank (turned off). I turn on com radio in the plane and tune on tower, but nothig. What I do wrong?
And one more question, why some AI aircrafts have wrong sound (for example cesna sound like heavy jet)?
First of all its works with last beta just fine. As you write it seem's that you dont turn on a-life window. Until you turn on all buttons are innactive. To turn x-life on press the only highlightet button in left corner in x-life window and wait to load. Then you must input your flight plan if you want to fly with x-life ATC. Then you can see atc buttons on top highlighted and frequncy too. Please read the manual.
I turned on x-life, it loads about 40 sec, all freeze at this time. After that AI traffic alive and I see it on radar and in windows. I input flight plan, but when I press buttom "Send flight plan to ATC", nothig happened, and I no see any error messages. ATC buttons still not active .
MadJohn wrote:I use X-plane last beta and bought x-life deluxe beta. In my x-life deluxe all atc buttons on top is not active and freq window is blank (turned off). I turn on com radio in the plane and tune on tower, but nothig. What I do wrong?
And one more question, why some AI aircrafts have wrong sound (for example cesna sound like heavy jet)?First of all its works with last beta just fine. As you write it seem's that you dont turn on a-life window. Until you turn on all buttons are innactive. To turn x-life on press the only highlightet button in left corner in x-life window and wait to load. Then you must input your flight plan if you want to fly with x-life ATC. Then you can see atc buttons on top highlighted and frequncy too. Please read the manual.
I think the problem is that the Airport is not x-life compatible, so x-life does not work on that airport.
Try another airport and x-life button will come alive
br
Frank
Hi. I tried to fly with A320 and xlife in VR mode. each time in flight, after 10 or 15 minutes, xlife ATC crashed xplane. I used xlife deluxe 4.20, and it's same thing with xplane 11 beta 15 - 16 and today beta 17 !!
I have no error message. just a crash of xplane. return to windows desktop !!
this is the end of log files :
0:52:24.914 E/DSF: The DSF F:\Biblio XPLANE\Custom Scenery\simHeaven_X-Europe-7-network/Earth nav data/+40+000/+44+004.dsf has a number of problems with its road network: 169 doubled nodes, 0 direction reverses, 0 short segments, 47 roads deleted.
XL: 2614 : Switch Center from Marseille/100000000 to Marseille/199805
XL: 2614 : ---+++--- ATC: VAL 123, contact Marseille Center 108.50 (S:78)
XL: 2616 : XPLMSpeakString-> VAL 123>, contact Marseille Center 1 0 8 point 5 0
XL: 2627 : ---+++--- Pilot: 108.50 for Marseille Center, VAL 123 (S:79)
XL: 2632 : ---+++--- Pilot: Marseille Center, VAL 123, Flight Level 189 (S:-1)
XL: 2632 : ---+++--- ATC: VAL 123, Marseille Center, radar contact, Maintain FL 190 (S:80)
XL: 2634 : XPLMSpeakString-> VAL 123>, Marseille Center, radar contact, Maintain Flight Level 1 9 0
XL: 2640 : ---+++--- Pilot: Maintaining FL190, VAL 123 (S:35)
Actually I have the same problem as Greazer mentionned but no one could understand. I use the free version.
When I'm performing pushback, if an AI is crossing the same taxi path, it will encounter my aircraft anyway while in pushback operation.
During taxi strangely the distance is respected and when you go slower, the AI one behind you will slower its speed. If you stop it'll stop.
But suppose the runway is clear, I still have that AI following me for longtime, I engage the runway, then the AI will engage too, not hold on the runway borderline, and ignore my aircraft passing throught it etc...
However during approach, the AI aircraft waiting for the runway to be clear won't engage while I'm occupying that runway. Which is normal.
In fact there is still that broken law for take off.
Have anybody else problem width X-life last version X - plane 11.50 RC2. I can't make any fly using width X-life, constantly closed X plane, without any report in log files. When I remove X-life from plugins no CTD and plane works fine.
Width X-plane version 11.50 RC 3 X-life works fine. Only followme cars blinking until FM Car find on what airport I landing. FM car width taxi map usualy take to much time to identified airport on plane landing. Many times I parking the plane and then FM car show map - but there is no need to show so late.
This is Exactly the Problem. For landings the other AI planes wait. For takeoff they just enter the runway and go. The AI takeoff as soon as your plane aligns ready for takeoff. Straight through your aircraft! It's CRAZY.
This is a Most ANNOYING thing which has been for years and never gets fixed. Why can't it be fixed?
Also another annoying thing, you MUST always fly from A to B where X-life has AI aircraft at Both Airports! You cannot fly from a small airport to an X-life airport or vice versa. Otherwise the Addon complains. This is an absolutely Stupid Oversight on behalf of developers. Ridiculous.
Please Fix these Annoying bugs. And please make ATC Optional for Flights i.e. flights with AI only! Obviously not EVERY user wants ATC on EVERY flight EVER, bar None!
Thank You.
Greazer.
Hi: I went ahead and updated X-Life for X-Plane 11.5 but it still does not work. Is there a solution? When can you conference via skype?
This is normal. Bugs are Not getting fixed. These developers are condemned, for: a) releasing a third rate product to begin with and b) not fixing said product. Letting it to waste.
XP 11.50 is now final and released.
X-life can now made final for the use with XP 11.50, after the repair of some reported issues of course.
Width X-plane version 11.50 X-life, when load, works ok. Loading time is enormuos long, when I turn on X-life X-plane freeze for 2 minutes until X-life loading. I have I7-10700K processor working at 5 mhz and 32BG of RAM.
Because X-Life is a horribly designed and developed product. Is hardly even supported by Developers. And paying customers have to deal with the most ridiculous bugs and errors. Almost as bad as Vulkan!
