1 (edited by lyonix 2020-09-11 16:39:53)
Topic: Linda does not call V1 and Rotate
Linda does not say "V1" and "Rotate"? Do I need to setup something in the EFB?
EDIT: Tried to reinstall Linda, but still no V1 and Rotate callouts from Linda. I am using Zibo Mod 3.43.11 and the lastest available version of Linda. Its wierd because other callouts like "80knots" and "positive rate" work. Maybe she somehow does not recognize the V-Speeds.
EDIT: I noticed if I fly a second leg on the second takeoff Linda actually calls out V1 and Rotate. Its only not working on the first leg.
Re: Linda does not call V1 and Rotate
You may call me skype j.a.romanov - we will check this issue online together.
I've this issue in the past as well.. sometimes she does call out the "rotate" commands, but other times not.
Has there been any update on this topic?
I am not getting the speed call outs either.
Can we get a solution please?
Scott
I am impressed by the script artist for creating this script to help people in designing  X-Life ver 1.2. Also, they can use nursing assignment to get more quality in their work. I want to thank you because your script really worked with max  X-Life ver 1.2 searchings for it for hours on the internet but I have found it on this website.
