Topic: LOAD and UNLOAD plane
Ground Handling has same sequence when aircraft load and unload (departure/arrived).
Is possible to make different sequence for LOADER?
We expect that baggage unload, not again load to aircraft.
JARDesign Group Board → General Discussion → LOAD and UNLOAD plane
Ground handling can not tell if you have arrived or are going to depart- and hence does not load/unload according to this.
BUT- you can edit the individual aircraft sets, so they make the baggage unload:You just need to change the "Animation 2" values of the loader as shown in the attached image, which causes the loading process to be reversed.
Hello, can you attach the image again because I am having problems with it
