Topic: CoPilotPlugin for ToLiss Airbus A321
http://jardesign.org/forum/img/m/22/t/p1e7vo7egp15d197jned1cfu1r3k3.jpg
REQUIREMENTS:
+ X-Plane 12.00 flight similator
+ Windows OS (7 .. 10) or MAC OS (Sierra .. Catalina)
+ Microphone or Headset
+ ToLiss Airbus A321 aircraft Version 1.4 + (not included)
+ Speech Recognition language should be set to English only (for Windows OS)
LANGUAGE: English
DESCRIPTION:
(actual version 180123, ToLiss A321 version for XP12 compatible)
Pilot job in a modern airliner involves two people. As you are a simpilot, you need someone who can listen to you, execute your command, read checklists, live with you. You can get this with JARDesign Copilot plugin.
She name is Linda. She is well-qualified Airbus A321 (TM) F.O./copilot. She have:
+ animated 3d CoPilot body
+ can recognize and execute your command
+ can speak with you
+ can read checklists
+ can operate with flight events (based on flight parameters detection)
+ can execute SOP (Normal Procedures, limited)
DOWNLOAD:
This product is not refundable, but You can download, install and test the demo version (Manual included) right now http://www.jardesign.org/copilotdownloa … PL-321.zip
Demo mode work up to takeoff phase of the flight. If you like the demo version and you want to use the full version - you may purchase serial key here https://store.x-plane.org/CoPilot-for-T … _1238.html
SUPPORT: www.support.jardesign.org
Old CoPilot version for XP11 you may download here:
http://www.jardesign.org/copilotdownload/JD-CPL-321.zip
Re: CoPilotPlugin for ToLiss Airbus A321
reserve
Hello, I am trying the demo, the menu works fine but I have no graphic of the FO. I have uninstalled and reinstalled several times
with no luck.
4 (edited by Michael 2020-06-10 13:12:23)
with no luck.
I've purchased this one too, same problem here. First installation, I can see the FO. Starting again X-Plane, the FO disappear.
UPDATE:
It looks more like the FO disappear when I run the aircraft autoupdate.
Michael wrote:
with no luck.
UPDATE:
Yes, need Ininstall / Reload / Setup after aircraft update may be.
with no luck.
You may use skype j.a.romanov for direct help
7 (edited by Michael 2020-06-12 11:42:30)
Michael wrote:
with no luck.
UPDATE:
That is what I do, but is quite frustrating, also because you have to digit the serial again (manually, it doesn't work copy&paste), etc...
Like me, so any other users own some aircraft and several plug-ins from you.
It would be a good idea to have auto-update software to update all your product in one place. I hope you will consider that.
Thanks a lot!
Hello it seams that the win.xpl file in copilot-main is lost, and it is imposible to instal the Copilot 321.
So re-install.  No problems with A321 install for me and the binary does exist.
Hello Downloadfile ist not kompled in Folder copilot-main contains only mac.xpl  und none win-xpl. This happend only by Copilot 321  and not by copilot 319.Copilot 319 copilot-main contains both mac.xpl and win.xpl. Teseted at 17.06.2020 13.31 zulu.
11 (edited by SnowMint 2020-06-17 15:34:56)
I can confirm. The win.xpl file is missing from the current download. see screenshot https://i.imgur.com/VCz8HVk.png Downloaded 2020/06/17
I also confirmed downloading from JAR and X plane Org store.  I downloaded from store june 9 and it was present.
This sucks that this isn't being addressed at high priority for perspective/paying customers.  Maybe they found a bug with vulcan support that was causing crashes for some on windows so they pulled that piece leaving mac support.
I don't think it would be approved if I  posted my downloaded package.
Hopefully, it will be addressed soon.
The download link posted in the beginning of this thread works perfectly. Or is that version not up to date anymore?
It appears that  the missing win.xpl has now reappeared.
Updated to version 160820
how do we add more voices to choose from in the drop down list? i have them in windows speech settings, but they do not show up in sim
I would like to put her on captain seat instead of a first officer seat.
If it can’t, I would like to remove F/O animation.
Is it possible?
ı just purchased 321 co pilot and entrered my serial but no linda at cockpit.reloaded aırcraft several times
19 (edited by skyranger321 2021-02-07 13:25:23)
Hello J. A. Romanov,
when will the „Copilot for Toliss A321“ finally get new updates and adjustments to the correct procedures?
I bought the software and of course I would like to see further development, thank you in advance for your efforts.
Here you will find the QRH Procedures and the handles for Pilot Flying and Pilot Monitoring:
Download (PDF): https://mega.nz/file/P4Y30YzS#LvV9hV9lV … JXxNjDRy9g
Many Greetings
I tried this in VR, works like a charm. I was wondering about some possibility to open the widget in VR as well. Please help, thanks.
21 (edited by mikie46 2021-07-27 01:08:37)
This version is MORE than a year old without UPDATES! Since then, most people have upgraded xplane to 11.55r2 using Vulcan + the A321 has been upgraded to the NEO version and advanced to v1.3.1.
Romanov has done ZERO, NOTHING to keep this software updated. And this version dated win.xpl 06/20/20 has all kinds of problems which he will take another year to fix.
I dont understand this Developer. He wants your money but he cant keep his STUFF updated. He must be very busy doing what?
This version has a problem with not being able to run the Flt Control Checklist. Linda stares at you but fails to run that checklist then she asks you LATER why you did not run it. Once you get to the RUDDER CONTROL she says nothing and ignores your left right check. Amongst other issues.
Pathetic!
Yeah I have emailed them before to update this plugin. I really needs it but no response. I Also have that silly issue with flight control check (rudder) so i just skip the controls check now which is not standard SOP.
Pathetic!
23 (edited by henkwijngaards 2022-04-07 14:33:54)
Hello I bought the copilot. It works well in Toliss A321, but the only problem I have when talking to the copilot she does not hear my commands. Voice activation is setup and Cortana recognize my voice. As an example when I say How old are you. You see in the little voice screen that my command is heard. But then I don't get an answer. But by clicking on the commands I get the answer. Do you have advice how to fix the voice recognation in Copilot for the Toliss A321?  thanks in advance see screen shot.
Attachment icon Jardesign Copilot A321 Voice recognation does not work.jpg 270.38 kb, 53 downloads since 2022-04-07
Hi ,
I have the same problems I did all the instructions as in the manual but it still does not work .
Birol
henkwijngaards
Hello! Voice recognition issue may be checked via Skype support. Please use Skype j.a.romanov
