Topic: Pilot not visible
Hi i just bought the copilot for the toliss a319 and the pilot is not visible in neither high or std def. sounds and everything else works but the copilot is not to be seen? sad
toliss a319 version is 1.4
Re: Pilot not visible
Same here. Not visible in toliss a319 version is 1.4
For 1.4 please use this version http://jardesign.org/forum/viewtopic.php?id=11890
Co-pilot is showing now thank you. Accepted serial number and did Set-up when asked. Rebooted computer twice and still will not pick up any voice commands.
Manual included into ZIP pack described voice setup in details, but sure, you may call me skype j.a.romanov if need help - we will check it together.
You need to assign a button to the command “commandrec” hold the button Down and talk, works here smile
I have your A320 Co-Pilot and never had to do anything to get that to work. I did see your instructions and nothing looks different or does it have something different?
My head phones work correctly on other uses. When I speak it does recognize my voice but the co-pilot does nothing,
Ok. Setting commandrec worked. I did not see that in the instructions though.
As you can read in Manual: If you prefer voice control, you need setup special joystick (sure, keyboard may be used too) button to jd/CommandRec. You may look at CoPilot, hold this joystick button and say something like "Hello!" Typical pattern - press the button, say the text, release the button.
Anyway - if you get it worked with JD320 - it should work with TL319
Does this copilot start engines like the A320 copilot? The A320 does everything from APU start up and start the engines. Do this one for the Toliss do that?
I should say what this plugin have another base plugin compare with all other - 320, 330, 767 copilots. TL319 copilot based on Visual Avionics plugin by JARDesign. We spend 1 year to build this. This plugin allow to do everything. But next stage - just see.. How it will work on many-many users setup. If this plugin will be usable and popular - we will invest time and money to add all Normal procedures for it.
I'm using the last version but still the model doesn't appear.
When using in the Cessna, I can see the pop up showing that created the new acf file but this doesn't show up in the A319...
could someone help me?
We didi it, still the same problem.
I also opened a ticket, it is still there unsolved..
My skype - j.a.romanov
This way will be faster.
Latest version form the sticky post solved every issue I had.
Pilot is visible and working.
