126
Re: XP11.41 JD330 v.3.3 r1, r2, r..
noisimus wrote:
In  simbrief I download the flight plan for JAR Airbus (format .txt) at the bottom of the page . Then I copy it in the flight plans folder of The JAR A320/330 . After I enter the coroute (ddddaaaa) .
And … no problem …
I'm using Aerosoft PFPX and copying the ATC route from my briefing package into a txt file, still getting segment errors despite having valid AIRAC installed, and manually entering the route has no issues. It's a long route so it's just a pain to entire every airway and waypoint.
Will try SB and see if it gives a similar route.
Hi I must say that I have not used yet a flight plan for going to USA from Europe .
I have been told to use GPS coordinates for such a flight .
That's the problem im having,im trying to do a long flight but everytime I go to upload the flight plan theres to many segment errors.
128
informatics.java wrote:
JD A330 has some bugs like engine shut down problem. Please check this issue.
Okay...glad I'm not the only one.  After long flights, the engines won't shut down for me.  I turn off the fuel cut off switches and the engines spool down to idle...and stay there (and fuel pumps off doesn't help).  Hopefully the cause for this can be located.
If you have problem to shut down ask the co-pilot to do it - he knows!
130 (edited by Fab10 2020-02-13 22:54:07)
I’m sorry, I quoted the wrong thread.
The problem I am having is when using reversers, and my engine EICAS and displays temporarily switch off. They are restored when my levers return out of reverse.
Sorry to say that I have the same issue with a fresh copy of R2.
It is as if my systems are switched off momentarily because when my reversers are brought back to idle, I can hear the cockpit startup sounds (from my BBS sound pack).
Fabio
8/10 times flying the Jar A330 my sim crashes. Not happening with other aircraft. I want this fixed or I want my money back!
132
10/10 times Jar A330 dont crash my system. Is the plane or your system?....
133
The same for me …
The same for me …
As a result of these problems with the A330 in the last week I have to go fly width ZIBO B738-900 free airplane. With this plane there is no problem with the crash of the system. The interesting thing is that I'm using the JAR X-life plugin with this plane, and all is ok no CTD. Somewhere there must be a glitch or an incompatibility A330 with the latest version of X-plane.
135
The same for me …
As mentioned above JAR A330 latest version and X-plane 11 (also latest version) works fine for me …
I'm happy for you, but it isn't my system.
As it happens, after this started to occur, I did a fresh installation of
- Windows 10
- X-Plane 11
- JARDesign A330
and the problem still occured.
I take off, fly a little while, but somewhere between 20 seconds and an hour after takeoff I get numerous warnings (for no apparent reason) and the sim crashes.
Also I'm fairly sure I've read somewhere others had the same problem.
137
And what say your log.txt?
138
Greetings busdrivers,
I have so far enjoyed my recent acquisition (A couple of days ago), but the thing that bugs me the most is that COM1 and COM2 tend to follow each other when tuning frequencies.
I also have a big problem since it's impossible for me to switch from one COM to the other (very handy when on VATSIM).
Any suggestions on what to do, or is it a known limitation? If that's the case, I'd hope for a "fix" soon.
Cheers captains, blue side up.
139 (edited by ddezulier 2020-03-04 08:51:28)
What I'd noticed is that JARD A330 is very sensitive to other plugins. You need to deactivate all of them and try A330 on a naked X-Plane platform and then reactivate those you need except the one which appears to reproduce the fault.
I'd noticed too that it is almost the lone plane of my hangar to have such plugins compatibility problems.
I guess there are many different methods to access X-plane resources and to handle one's own flight model.
ddezulier alias diaboloxpfr on X-Plane.org forum
VID 566478
VAT 1400805
pls update!!!!
Dear developers,
First of all, I think from an exterior point of view the A330 is pretty well made. There is one thing that needs to be improved which are the tires of the landing gear (NLG and especially MLG). They need to be wider. Spot the difference, left real life, right JAR A330
142
I can't see if pictures are attached but I will try again....
Attachment icon airbus-a330-main-landing-gear-DJHD7F.jpg 217.24 kb, 70 downloads since 2020-03-17
143 (edited by ddezulier 2020-03-18 20:00:36)
On Michelin Tire Datasheet
(https://www.jupitor.co.jp/pdf/michelin_aircraft.pdf)
it is
M x N - D or
M x N R D  where "R" means radial
M = overall diameter (mm or inches)
N = max section width (mm or inches)
D = rim diameter in inches
For A330 main gear wheels it is
1400 x 530  R23
54 x 21.0-23
For front gear it is
1050 x 395 R16
no dimensions in inches
under Plane Maker dimensions are in feet
semi radius and semi width
for main gear it should be
2.25 x 0.83
for front gear it should be
1.72 x 0.64
On the JarDesign model :
the front gear wheels are too big
1.81 x 0.72 instead of 1.72 x 0.64
the main gear wheels are too small
2.03 x 0.75 instead of 2.25 x 0.83
plane has to be fixed
VID 566478
VAT 1400805
144
Bugs
- Black screens when using reverse thrust, screens restart again when throttles are idle.
- Black screens after departing with a turn around flight.
- I can't use the ECAM when the engines are not running.
This aircraft is not worth it for the money it costs.
145
CoenPiloot wrote:
Bugs
Log.txt file please
Dear Mr Romanov, jdsp,
Will the tire error bug be fixed in an update? Highly appreciated.
R
CoenPiloot wrote:
Bugs
I also experience the black screen on reverse thrust and the black screen on turnaround also. Very frustrating.
148
Veekal wrote:
CoenPiloot wrote:
Bugs
Veekal wrote:
CoenPiloot wrote:
Bugs
Same here as well as the airplane is almost incapable of managing it's airspeed during descent
150
RSpeekenbrink wrote:
Veekal wrote:
CoenPiloot wrote:
Bugs
If you have an old or cracked version you obviously have these problems, I have never had these problems on my 330....
