Topic: FF 777 er does not work
why i have this problem?
I am very disappointed with the product
JARDesign Group Board → Users SETs for X-Plane aircrafts → FF 777 er does not work
This is because you don't have a set installed for that particular aircraft. https://simliveries.com/index.php/2018/ … er-ff-set/ This should work for the FF777er.
Nope, @chxry, that's the one that doesn't work....
at least not in my install..
This things are out of place...seems to be the positions of the 777-200
May be you need just visit our http://simliveries.com/index.php/category/ghd-set... to check what aircraft(s) have compatible sets to work well with GHD. Next you can download .set file and put it to ../X-Plane/Resources/plugins/GndHandling/Sets/Custom/ folder.
If no set there for your aircaft, another way may be used. Open ../X-Plane/Resources/plugins/GndHandling/Sets/Default/ folder and find .set file what may be good for your aircraft by name. Take this file and put it to your aircraft folder, close to .acf file. Next - rename .set file with the same name what used for .acf file. So, if you see b737.acf file you should rename set like b737.set This trick will allow you to try to use any of exist set with any aircraft you want.
