Re: XP11.41 JD330 v.3.3 r1, r2, r..
FOLKS:
JarDesign A330_v3.3 r1 IS NOT WORTH TO BUY OR TO UPDATE - sorry, but its TRASH!!!
JARDesign Group Board → Downloads, Updates. → XP11.41 JD330 v.3.3 r1, r2, r..
FOLKS:
Will the radio panels and MCDU's be independent?
And that is because you are an real A330 pilot or ???
It is easy to say that something is trash, but then substantiate it why it is trash and give proper examples.
Cor
FOLKS:
You said that twice, I hope that was a glitch.
Anyway, confirming the nosedives. Yesterday I’ve done a flight, things mostly went smooth until the approach phase. It looks like a mix of two problems: 1) prioritizing the altitude over speed and 2) inconsistency of the decent profile. Can’t comment too much on the second one but for the first, most of the modern jets autopilots prioritized the speed, because it’s simply safer.
I have a question
Is the UTC CSTR function coming, we have ALT and SPD, but i was wondering if the UTC function is coming (where the aircraft will set a speed to arrive at a waypoint at X time)
FOLKS:
An ill tongue may do much.
Please respect hard developers.
Hi everyone is the 330 auto tune the vor's I have nothing on the ND display on the latest build
cheers mark
@bascon 1
I just made a flight from Stuttgart to Zürich. Everything was okay. No issues at all. Can you imagine! ;-)
So please don't be so impertinent and respect the developers.
Bernd Schwarz
hello, a question, I bought a330 recently, I have 5 beckup keys, at every update I have to use an activation, but after 5 updates I have finished the activation keys? thank you
When you finishes your activations number (updates or reinstallations) you only need to ask for a few more on "support" forum and have to indicate references of your purchase order .
в отличие от 3.2 автопилот не держит скорость на эшелоне. После набора высоты скорость медленно снижается, но автопилот не добавляет оборотов двигателя для компесации и, в итоге, отключается
Just had a flight from LGAV to EGKK and during the descent it did his nosedive
and on the ILS it went hirewire.
I will put the A330 for now in my virtual freezer and will take my 777-200 for tomorrows flight.
Hope the bugs will be sorted out soon.
Cor
Downloaded and tested the new version.
Unfortunately still more bugs than features
DIR TO not working as expected
Sec FLP not implemented
Climb still down to 500-600FT/M during speed up even if the plane is empty
Nose diving
etc etc
FMGS: 6253 : CurlDownloadFileSSL() fromWWW=https://tgftp.nws.noaa.gov/data/observations/metar/stations/CYVR.TXT
FMGS: 6253 : CurlDownloadFileSSL() toPath=H:\X-Plane 11\Aircraft\JD330XP11\plugins\fmgs\Metar/CYVR.TXT
FMGS: 6253 : JARDesign plugin error: Peer certificate cannot be authenticated with given CA certificates
FMGS: 6253 : CurlDownloadFile() fromWWW=https://tgftp.nws.noaa.gov/data/observations/metar/stations/CYVR.TXT
FMGS: 6253 : CurlDownloadFile() toPath=H:\X-Plane 11\Aircraft\JD330XP11\plugins\fmgs\Metar/CYVR.TXT
FMGS: 6253 : JARDesign plugin: H:\X-Plane 11\Aircraft\JD330XP11\plugins\fmgs\Metar/CYVR.TXT file updated.
FMGS: 6253 : CurlDownloadFileSSL() fromWWW=https://tgftp.nws.noaa.gov/data/observations/metar/stations/PAJN.TXT
FMGS: 6253 : CurlDownloadFileSSL() toPath=H:\X-Plane 11\Aircraft\JD330XP11\plugins\fmgs\Metar/PAJN.TXT
FMGS: 6253 : CurlDownloadFile() fromWWW=https://tgftp.nws.noaa.gov/data/observations/metar/stations/PAJN.TXT
FMGS: 6253 : CurlDownloadFile() toPath=H:\X-Plane 11\Aircraft\JD330XP11\plugins\fmgs\Metar/PAJN.TXT
FMGS: 6253 : JARDesign plugin: H:\X-Plane 11\Aircraft\JD330XP11\plugins\fmgs\Metar/PAJN.TXT file updated.
one day you will make decision what I did:
Two weeks ago I erased this calamity on my harddisk and
bought the Aerosoft a330 professional.
What a difference! After several updates (very fast by Aerosoft)
there are no issues so far.
cheers
Nose diving
etc etcFMGS: 6253 : CurlDownloadFileSSL() fromWWW=https://tgftp.nws.noaa.gov/data/observations/metar/stations/CYVR.TXT
True, the Aerosoft A330 is a masterpiece. In it wasn‘t on a far inferior simulator it would be my choice too.
JARDesign, the A330 alternative for X-Plane is RawDesign A330, which, as far as I know is a piece of crap.
You are our only hope! It is your mission to make the product decent!
Please!
Nie działa po aktualizacji pogoda z Active sky można ten błąd naprawić
Does not work after updating the weather with Active sky can fix this error
I found out that after 5 or 6 hours of flight, A/THR starts to behave erratically. Meaning that it wont hold the assigned speed, being it on managed or selected.
It looks like the calculated N1 or EPR is way too low for the actual weight and balance + actual winds, with results in the acft slowly losing its speed and, if nothing is done, it gets bellow the minimums, resulting in a stall.
Sometimes kicking in MAN TOGA until the proper speed is reacquired and returning to CLB solves the problem for a while, until it gets back. Sounds like accumulated error.
not working weather with Active sky XP you can fix it
why autopilot disconnected suddenly?
My Active Sky does not work with the aircraft, not even the default weather, is always marked as "Custom"
When investigating the problem related to default weather and Active Sky, it was noted that it is related to "JARDesign Virtual Avionics plugin", when disabling it in Plugins Admin, the weather operates normally, but the A330 does not .... FAIL
it is possible to fix this error?
Is it possible to make the plane good?
Or maybe to get a refund if not?
with all respect to the devs but it's unacceptable to
fly this airplane. Sometimes it's working, the other
time very annoying failure happen.
Sometimes I feel myself playing lottery!
To pay a considerably high prize for such a calamity
is simply an exploitation.
Sorry guys from JAR. Obviously you tried your very
best but it's not enough.
with kind regards
