Topic: JARDesign 330 Airliner - loading crash
Hello guys, today i bought this plane.
I dont like it so much on market is much more better planes but whatever.
I wanted to try some approach  3nm or 10nm and my xp11 always crashed.
Then i started do some research and i found this.
https://www.x-plained.com/review-jardes … s-a330-v3/
"An example would be the fact that I wanted to practice landings and tried to load the aircraft at 3nm and 10nm approaches. Each time I did this the whole of X-Plane quit immediately. I tried this at several airports with the same result.
Again this is very frustrating with no documentation. An email to the developers produced a quick, helpful reply that the approach function does not work with the A330 and the way to set up an approach is to take off and move the aircraft using the X-Plane map."
Is it true?Why there is no RED SIGN WARNING BEFORE YOU BUY.
Do all planes from JARDesign are same?
If this is true i will never buy anything from your crap anymore.
And i dont really feel this post is spam.
2 (edited by ilankrt 2019-05-12 21:31:52)
Re: JARDesign 330 Airliner - loading crash
This will be for sure more suitable for you. There are a lot of instructions how to fly with....
http://jardesign.org/forum/img/m/1591/t/p1damv7v5a1mqddpg9vl6qf6f3.png
@martin.masika
This feature of X Plane 11 applies only to laminar research aircraft.
For example, Cessna 172 SP.
euroking2018 wrote:
@martin.masika
Yes indeed it is only practicable with X-Plane small aircraft models...... I would like also to practise some APPR but no chance...
Loading crash airline information is here, Here is design which tells about the whole things which is according to the resumeprime.com review. These designs are best if these are creative and no one can judge these designs easily.
