Topic: Installation Problems
Hey guys,
I have recently bought my first X-Plane 11 Aircraft Add-Ons.
I wanted to read the installation document of the jardesign a330, but the folder is named MASCOSX (I use Windows) and I can't read the text ("   Mac OS X                   2   ù     +                                      ATTR      +   ¼   o                  ¼   S  com.dropbox.attributes          com.dropbox.attrs    xœ«VJ)Ê/HʯˆOËÌIÍL‰ÏÉONÌQ²R¨VÊMLÎÈ̉%–”…RK %í€`ƒâ
“Œ*Ws÷ÔÄ@ÿP³
çt[[¥ÚÚZ ¿í(
5¯„<¦7      <VŠµ† ").
What shall I do?
Thanks for your help!
Re: Installation Problems
xtreme1 wrote:
Hey guys,
“Œ*Ws÷ÔÄ@ÿP³
çt[[¥ÚÚZ ¿í(
5¯„<¦7      <VŠµ† ").
What shall I do?
Open folder OpenAndReadMe there is Windws instalation. You dont need ___MACOSX.
I did that now, but still the same error messages are popping.
- "a330 systems (SASL) plugin not activated"
- "Please check your aircraft installation"
- "Please check whar your aircraft was activated"
Moreover there is a warning "Ground Handling plugin is not installed", but I got the deluxe version and it works.
Don't know what to do.
Looks like you haven't activated/registered the aircraft
Yes, I think so too, but how can I do that?
Remove what you have from your Aircraft folder. Download a fresh copy. Put it in the Aircraft folder. Start XP and select the A330. When it loads it should prompt you to activate, asking if you have a serial key. If you do, paste the serial key into the box and follow further instructions. When it says the aircraft is successfully activated, quit XP and start it up again. The A330 should then work as expected. All of this is also explained in the Instructions that come with the AC.
  - make sure, that you use X-Plane 11.11r2
  - copy unziped "JD330XP11" folder to ..\X-Plane 11\Aircraft\ folder
    (make sure you don't use nonEnglish symbols in aircraft's installation path)
  - please visit http://handling.jardesign.org and download the latest version of Ground Handling plugin. It works with JARDesign 330 without registration (for free). No registration need. No serial key need. Please note that the “Deluxe” version of this plugin (may work with other aircrafts) is payware.
  - start X-Plane 64 bit and open JD330, activation window will pop up ***
  - select automatic activation
  - enter your serial key (Regcode), click NEXT and after a successful activation reopen the aircraft via
X-Plane menu -> “Developer” -> “Reload the Current Aircraft”
*** - if no activation window appear (for Windows users):
1. Check what you use computer under Admin mode.
2. You use Windows 7 or 8 or 10. In this case, please install "Microsoft Visual C++ Redistributable 2010" pack from here:
https://www.microsoft.com/download/deta … x?id=14632
(create it if need)
SUPPORT:
http://support.jardesign.org/
LIVERIES:
http://simliveries.com/
Updates, Docs, FAQ, HowTo, e.t.c.:
http://jardesign.org/forum/
OFFICIAL WEBPAGE:
PRODUCT FORUM:
do you know, I agree with you, but how can I do that?
let's get at this casino online bonus
now
Installation problems is ever get in all the time. If you want to get solution of this installation problem then you can easily solve this problem who just have bestessays. I would like to show you all the installation problems which ever we get in most of the time.
