1 (edited by danielrevans4 2019-06-20 20:24:30)
Topic: How to use with EMB 145?
Hi, I just got this and read the manual but still can't figure it out, can someone help? I have the XCrafts EMB 145 loaded up, i open the control widget, press drive up, and nothing happens. or rather a couple vehicles pop up and sit a way away and dont move. i tried to move them by clicking on them and dragging but no joy.
am i missing something? how can i make them drive up and service the jet? thanks!
Re: How to use with EMB 145?
May be you need just visit our http://simliveries.com/index.php/category/ghd-set... to check what aircraft(s) have compatible sets to work well with GHD. Next you can download .set file and put it to ../X-Plane/Resources/plugins/GndHandling/Sets/Custom/ folder.
If no set there for your aircaft, another way may be used. Open ../X-Plane/Resources/plugins/GndHandling/Sets/Default/ folder and find .set file what may be good for your aircraft by name. Take this file and put it to your aircraft folder, close to .acf file. Next - rename .set file with the same name what used for .acf file. So, if you see b737.acf file you should rename set like b737.set This trick will allow you to try to use any of exist set with any aircraft you want.
thank you, i will try out your suggestions
