Topic: XP11 and Groundhandling - cannot see the plugin
Hello there,
i have just purchased the Ground handling, but after copying the GndHandling Folder into the Plugins Folder i cannot see nor acitvate in in XP11.
Any solution?
Thank you!
JARDesign Group Board → General Discussion → XP11 and Groundhandling - cannot see the plugin
Hello there,
Any solution?
Thank you!
Hello there,
Any solution?
Thank you!
Can you upload a screenshot of your plugins folder?
long time ago.
Found the problem which - for me - is a quite big one.
When Xacars is in my plugin folder, GND Handling is not shown in my menu, if i remove Xacars GND Handling is shown.
Due to the fact that i need Xacars i can either use one or another... Any solution?
P.s. SOLVED - Issue was the XACARS installation. I had the Folder and 32 64 Folders seperatly in my plugins folder. Sorted them and now both works.
I have just purchased the Groundhandling, but after copying the GndHandling folder into the plugins folder, I can not see the plugin inside X-Plane 11 to enter the serial number, please what should I do? Can someone help me?
