Topic: GNDHandling Disappears
Hello guys,
I have a problem. I have installed and activated the GND Handling as was told in the manual. However when I "Drive Up All" the GNDHandling stuff appears, vehicles start moving for a second and then everything disappears. It happens with default 747 and Zibo 737. (I have a set installed for Zibo already)
What am I doing wrong?
Re: GNDHandling Disappears
Same problem!
Same here.
I wasn't expecting this mush help the developers!
This is their own forum for God's sake!
Same here. I've downloaded the latest set that I could find and it still doesn't work. This is the only plane that I usually fly.
Same here. Appears and immediately disappears with X-Plane 11.30b2
7 (edited by flavio58 2018-11-04 15:28:12)
Solved. Unistall and reinstall, works perfectly with beta2. Thanks Jar, now stairs, catering and loaders can find 737-800 zibo doors open!!!
Well does not work for me..tried this as well
Same issue here, only in the Zibo, reinstalling did nothing. Please fix this..
try beta 3 and so forth...
If you use beta versions problems are to be expected
Where are the betas? I am just using the latest one from their post.
I was referring to X-Plane. GNDHandling works well with X-Plane 11.26rc2
Gents,
I have the same problem in both XP11.26 as well as the beta (b3)
It seems that the Ground Handling is on a timer and about 7 minutes after activating it in XP it disappears.
It then ALSO kills the parking brake behind the scenes and trips the Autogate as well.
It also prevents Better Pushback from connecting to the Zibo as the parking brake is "tripped".
In the meantime the parking brake IS NOT off and visually still enabled.
Can you please fix this for us soon?
Best regards,
Nico
I am on 11.26, and I don't want to try the betas, that will probably just break more things. This only happens with the Zibo, no other aircraft. I just disappears every single time.
May be you should ask the zibo designer …
I already have, but something tells me this is more of a GHD issue than the Zibo, other people have reported it happening in the 747 as well.
Gents,
So while troubleshooting the issue, since reporting it here, I found the following;
** Tested with the Zibo 3.31g2 as well as the default 747 on both XP11.26 and 11.30b3 ***
GHD works perfectly fine for me when Autogate is removed from XP
Can you confirm if you have the same?
The moment Autogate is laced back then I am back to the issue reported earlier
Hi sKYMATIX
Thanks for this information
Guys here is more information to consider,
After removing Autogate and GHD stopped disappearing as previously mentioned
I happened to stumble on some of my older scenery that contains Auotgate as a part of the scenery design... same thing happened. GHD will work and 5 to 7 minutes later it times out, the Auotgate retracts and Better pushback refuses to connect as it thinks that the parking brake is off while it still shows on.
Maybe in a future update of GHD you guys should give us a switch to enable disable the GHD regardless of parking brake state??
I do not see any other solution yet. I believe that this could take care of any old or incompatibility issues.
Work fine for me: check parking brake set https://i.imgur.com/OoGhtLb.jpg
Works for me if I go to plugin admin, and disble autogate as some said over here.
So there is some kind of conflict with autogate and GNDH.
