Topic: Embraer ERJ-195LR by X-Crafts
A few notes about this set:
1. I built the set to be used with either 2 passenger buses (Neoplans) or a motorcade of limos and vans. Choose whichever you like and you can delete the others (either from the Build Aircraft Set option in the plugin menu, or by deleting them from the text file). Of course if you prefer to have all of them, no changes needed. I have included pictures of all 3 scenarios.
2. I definitely recommend using the "Drive Up" option from the plugin menu or the control panel as the delays and speeds are closely coordinated to prevent collisions, vehicles moving out of sequence, and other weird stuff.
3. The set includes cones and a GPU, but if you prefer to use the cones and GPU included in the X-Crafts plugin, you can delete these as well.
4. One problem I couldn't correct was with the front stairway. The travel height of the stairs is lower than the cabin door of the aircraft, so there is a strange upward motion just before the stair platform moves to the correct position. It raises the stairs into the side of the door, and then lowers to the base of the door. It drove me crazy, but I couldn't figure out how to correct it. Would love for someone to tell me if you now how.
Enjoy and let me know if you have questions/suggestions.
*The X-Crafts ERJ-195LR can be purchased at this link: http://store.x-plane.org/Embraer-ERJ-195LR_p_318.html
**The photos for this set include vehicle textures by Jusku which can be downloaded at this link: http://forums.x-plane.org/index.php?app … file=26998
