Topic: Feature suggestions and bugs
Would it be possible to have AI aircraft without the need for a flight plan.  Sometimes I like to just fly from point A to point B with some AI aircraft but without the hassle of flight planning and interaction with the ATC menu.
Also, a real immersion killer which needs fixed is the speed of AI aircraft after takeoff.  Every time I takeoff, the following aircraft takes off immediately behind you and speeds up to 300kts, giving a you a TCAS warning.  Would it be possible to set AI aircraft to 200kts below 2000ft then 250kts up to 10'000ft, this would resolve all these problems.
Lastly, can the ATC command to reduce speed to 250kts be deleted. There are many regions in the world where the 250kt rule often does not applied (Scotland for example), it's nice to do realistic flights with ATC giving unrealistic commands.
Re: Feature suggestions and bugs
Well, that was worthwhile, 150 views and not one comment from the vendor.
Looking at the continuous spam on this forum and the non existent discussions in the general discussions forum, I basically give up with this software.
