Topic: [actual] GHDeluxe v.040118
This is Ground Handling Deluxe plugin by JARDesign v.240317 distributive (Win 7/8, MAC OS 64 bit)
http://jardesign.org/forum/img/m/22/t/p1a9kuc5823gthmbaomic1t9c3.jpg
What new:
+ incoming JD330 ver.3 ready
+ add custom datarefs for aircraft developers
Download link http://jardesign.org/gndserv/download/GHD.zip
     1. if need - Save your custom sets from ..X-PLANE/Resources/plugins/GndHandling/Sets/Custom/
     2. save your key.reg file from ..X-PLANE/Resources/plugins/GndHandling/
     3. be sure, that you use X-Plane 10.42+ or 11.00
     4. delete old «GndHandling» from ../X-PLANE/Resources/plugins/
     5. copy unzipped new «GndHandling» folder to ../X-PLANE/Resources/plugins/ folder
- If you have key.reg file from prev version
     6. Paste your saved key.reg file to ..X-PLANE/Resources/plugins/GndHandling/
     7. Paste your saved custom sets to ..X-PLANE/Resources/plugins/GndHandling/Sets/Custom/
     8. Your plugin is always registred
- If you perform New installation
     6. start X-Plane 64 bit and load default Boeing 747
     7. Use X-Plane menu and select the Plugins->Ground Handling->Registration menu and enter your email and the serial key. Next press the SEND button and please check your e-mail. within 1 hr. You should get activation code must be entered in the 'code' field and press CONFIRM. Your application must work well now. If necessary to reinstall, please use the same e-mail and serial number.
     8. activation works well with both MAC/WIN 64 bit
http://jardesign.org/forum/img/m/22/t/p1a9kudbuikvo1b5o1f911i2m1p3u7.jpg
If you want post own liveries for GHD, you may use www.simliveries.com
Re: [actual] GHDeluxe v.040118
Still no HotKey activation? Not great, simple thing but an importantant requirement, will cost sales?
Many thanks as always for the update, you may want to change the version number its still referenced as 240317. Thanks again
Will this make work always the GND with the Zibo's 737? Sometimes work and sometimes doesn't. Quite random.
Btw, I also find unexplainable that the plugin doesn't have a shortcut... sad
Set parking brake ON then activate GHD.
I'll try that! Thanks a lot! smile
