Hi @jardesign  first of all thanks for the great job with x-life  and A320 , but I have an issue with x-life, I have been using for about 8 months now, When I started using it everything was fine all the certified airports were working fine even with the Xplane 11.10 Beta, I decided to delete the whole sim and reinstall fresh xplane and just the add ons I mostly use but now some of the certified airports like KRIC (Virginia USA, KEWR Newark new jersey USA) in x-life don't work. When I turn X-life on in those airports it crashes the whole sim. I tried the newest version beta of x-life  and many different things people told me to do but nothing works. Anything I can do to fix the problem ?  thank you very much.
27 (edited by wesader 2017-12-07 09:43:44)
Hi x-plane 11.10b3, X-life 2.1b3, ff757v2 extended, New Aerosoft frankfurt main EDDF airport very quit airport , not moving traffic, only few planes parking.
but Today are a little moving traffic only long haulers 388, 763, 777, no smaller planes...
More and more ai planes came up when waiting now its look good i think no problem.. maybe smaller planes goes other airport Frankfurt Hahn i think..
no problem i forgot this
Download the EDDF.xlf file from http://jardesign.org/forum/viewtopic.php?id=3540
28 (edited by pwalchester 2017-12-10 05:46:15)
Hi, 2 test flights both EGLL-ENGM, one with JAR A330, one ZIBO 737-800
X-Plane 11.05, X-Life 2.1b3
Crash to desktop approaching T/D both flights as arrival airport flights are loading into X-life.
No x-life.dmp files produced, log files sent to JAR
but log.txt ?
30 (edited by wesader 2017-12-09 21:03:21)
good evening. CTD When unloading Aircraft in Aerosoft EDDF v2 airport, x-life generating ai traffic same time.
hi. CTD again same airport when idling.
CTD when appr to efhk
Hmm.. Very stable crash..
And xlife.dmp file was never created?
34 (edited by wesader 2017-12-10 09:10:50)
wait i try find out, here it is next time i send always those both files.
hi EFHK to UUWW goes very well without CTD i set a bit lower, airport interval from 40% to 30% and RNW operations % from 3,5 to 3
36 (edited by pwalchester 2018-01-17 06:20:37)
Hi, test flight ZIBO 737-800, X-Plane 11.05, X-Life 2.1b3, LFPO-EDDF. Programmed FMC, called for pushback then CTD. xlife.dmp file this time.
37 (edited by frokka 2017-12-11 01:38:14)
Was at JFK and had a flight take off and fly to negative altitude, was green on radar.
Kept decreasing altitude, but did not crash the program.
AMX922 , E145 to KBGR
Windows 10 Home
Asus Radeon RX 580 - 8GB
Apogee Duet
Is there any chance you can resync flights with the server manually? For example after changing zulu time in the sim?
beta 4 of version 2.1 just posted. Need Update only .xpl files (attached at first post)
Improve stability (2 kind of crash fixed, based on users report/dump files)
40 (edited by ilankrt 2017-12-11 14:12:03)
Test flight EFHK to EVRA, A320, XL v.2.1B3 X-Plane 11.10r3 :
2 times sim frozen for some seconds
Strange reflexion of cockpit windows on the background of clouds as I changed view to outside (circle) - image
http://jardesign.org/forum/img/m/1591/t/p1c12uf5kd1r8ht8h1f654oc1cdo3.png
Hallo JAR please have a look at this occurrence....
41
Hi, Pleased to report repeat test flight EGLL-ENGM with ZIBO 737-800 which previously caused CTD has completed with no problems, X-Plane 11.05, X-Life 2.1b4
Test Flight FF757v2ext. XL 2.1b4 x-plane 11.10 released version shadercache folder was cleaned. KSFO -> KLAX flight route=  OSI DCT AVE DCT EHF , 2 DCT spots X-life accepted those very well ai traffic looks very nice and realistic, after all fly goes very well not problem at all. I add image for my X-life settings
Look like 11.10r3 bug or one of installed plugin conflict. Anyway, X-Life not draw any to cockpit or cloud.
44 (edited by gussgull 2017-12-11 21:49:49)
hi jar love xlife is lots better then wt3 just when can we have full voice for atc we have the real world flights just need the atc voice comunications so you could here ai chating to  atc thanks for xlife
45
Question re the automatic airline schedule function (which is amazing, nice job):
- Does X-Life query the current (real-world) Zulu time or the time set in the X-Plane simulation?
For example, let's say it is actually 16:00Z but I've set my simulation time to equal 08:00Z. Will X-Life pull schedules for 16:00Z or 08:00Z?
46 (edited by frokka 2017-12-11 23:42:08)
Beta 4 is crashing the audio engine after some 30-40 minutes.
Seems to happen consistently, have to restart XP to get audio back.
Windows 10 Home
Apogee Duet
is real world schedule correct because lots of traffic after 00.00  here in uk  when there should hardly be any ?
48
real world schedule is correct, sure, but may be you need read how plugin work at my first post of this topic. If user sen some flight interval like 2 minutes for now, plugin will try to find time-closer flights to generate it after 2 minutes.
49
THis info at log:
XL 3D Sound Engine Disable
Clean exit from threads.
NOT mean what sound was crashed, but what sound was exit correct.
50
The new beta works fantastically with the 'real flight plans' !!! Great Job! But please change the 'AirBerlin' Liverie in Germany by 'Eurowings' and / or 'Easyjet'. wink
