Topic: system minimums question
Has anyone actually tried to run this aircraft on an older Imac?  Any experience would be welcome before i buy it!
I have an airbus type rating in two months, and need a practice sim.  cheers.
iMac (27-inch, Late 2012)
3.2 GHz Intel Core i5
24 GB 1600 MHz DDR3
NVIDIA GeForce GTX 675MX 1 GB
Re: system minimums question
24 GB 1600 MHz DDR3
Should be no problem at all....
Graphic card memory seems too low ...(see required configuration)
yes maybe too low that is why i was asking if anyone HAS TRIED it.  Rather than speculate.
id accept a slower frame rate if still usable. Or turn scenery down to minimum levels when using the plane.
cheers
cheers
It was a polite form to answer (Not speculating).
If you have a JAR Aircraft you can see recommanded configuration ... so 1Gb is too low .
Bear in mind that if you want to use X-Plane 11  with custom airports you will need more resources and the very limiting part of computer is graphic card memory.
Miracle does not exist ...sorry
