Topic: JD330 Airliner ver 2.2 RC1, R2, R3 WIN/MAC 64 bit (X-Plane 11)
I think this is last version before "big" update to future v.3.0. So, we made a number of changes to improve JD330 stability. Sure, we work on major improvement, include new FMGS, but this is a long way.
Download link: http://jardesign.org/a330/download/inst … 30XP11.zip
Please install new version of Ground Handling to be well-compatible with XP11
Download link: http://jardesign.org/gndserv/download/GHD.zip
Next:
- be sure, that you use X-Plane 11.00r1
- copy unziped "330_JARDesign" folder to ..\X-Plane 11\Aircraft\ folder
- please visit download more fresh version of Ground Handling plugin. It work with JARDesign 330 without registration (for free). Please note what “Deluxe” version of this plugin (may work with other aircrafts) is payware.
*** - if no activation window appear (for Windows users):
1. Check what you use computer under Admin mode.
2. You use Windows 7 or 8 or 10. In this case, please install "Microsoft Visual C++ Redistributable 2010" pack from here:
https://www.microsoft.com/download/deta … x?id=14632
(create it if need)
What new in this version:
R2:
+ X-Plane 11.10 compatible
RC1:
+ improve stability
(more than changes in code, mostly for flightplan part)
R3:
+ Right Engine shut down issue fixed for XP11.11+
About serials and activations:
- All beta-testers, who have personal serial from JARDesign may use it with XP11. If problems - please skype me or http://www.support.jardesign.org
- All users who bought the A330 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A330 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
This JARDesign service should help for any users, what have a330 from any shop http://jardesign.org/a330-jd-x-plane-11-update/
Update fee is about $19,95 (not include VAT for your country). Sure, you own a330 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
Thank you!!!!
