Re: JD330 Airliner ver 2.1r1 WIN/MAC 64 bit (X-Plane 11)
Still no answer from the dev on this "E46 Teleportation Bug"?
Reuploaded the plane and reactivated and no more E46 Teleportation bug .... for about 5 flights !!!
Now the problem is here again
So for me A330 and 320 will stay in the hangar waiting for a next release ....
53
Yeah...I made a tour across Europe and at the first legs I experienced that bug and then it disappeared for next couple of legs until it hit me again a couple of days ago...
Will the failure panel option added again? I saw it in some pictures of the jar330 2.1b
55 (edited by SinusJayCee 2017-06-23 16:54:03)
Is there any news on the speed brake issue? I've the same problem.
Hi Good evening what's the problem of this photo?
When I start to descend after a moment Suddenly simulator ran into a problem and paused and after a moment the aircraft loaded on the ground like I crashed!!!!!!!:((((((((((( whats the problem???????
system info
CORE I7 6700HQ
RAM 16GB DDR4
GTX960M 4GB DDR5
Which photo?
58
http://s8.picofile.com/file/8300311000/photo5983561172374366624.jpg
59
Looks like a problem with FlyForLua to me. Do you have additional plugins installed and did you try to disable them?
I also tried it without Fly with Lua, and this thing Happened again...
61
Another thing is that when I pause the simulator the number of "Press" Page in Lower Ecam get hidden...
http://s8.picofile.com/file/8300416876/Capture.PNG
I suggest to contact the developers directly. I haven't heard about issues like this.
Got the same problem with pressure too
64
Hello. Have also problems with the speed brakes. They work on the ground. After that they do not go anymore. And just before landing, X-Plane crashes and I find myself on E46.
65 (edited by Balusche 2017-07-16 21:54:18)
Here are the pictures
http://jardesign.org/forum/img/m/4428/t/p1bl6lrqm31g8l1i4u17ntiq17i95.jpg
http://jardesign.org/forum/img/m/4428/t/p1bl6l2u681ie8nu51ffa7tk7qg3.jpg
http://jardesign.org/forum/img/m/4428/t/p1bl6l2u681eho5ca1jchanl1jfv4.jpg
Whilst I still get this major bug as well, keep in mind you're also using v2.0 R2 and not v2.1 R1. People can dismiss this unless it's on the newer version.
67
I have also tried ver 2.1R1 and the same error
68
Скажите будет ли дальнейшая разработка самолета? Tell me pleas, there will be further development of the aircraft?
Hi all, After many investigation about the"E46 Teleportation Bug", it seems that bug occurs when the "Custom Data" xplane folder contains GNS430 data.
I've try many flight from WSSS to WMKK with the route MASBO A457 GUPTA. Each flights with GNS430 folder cause  the "Teleportation Bug". Today, I've make again this flight without this folder (only _navdata plane folder) and everything was fine.
My 2 Cents
My 2 Cents
All my flights with the a330 have that folder. yet the bug only happend 3-4 times (out of 20 flights)
