1 (edited by Devirex 2017-06-01 19:00:23)
Topic: LGKR Xplane 11 Problem
i have tried to get some own created taxi routes working with XLife on a small Airport LGKR from tdg:
http://forums.x-plane.org/index.php?/fi … orfu-xp11/
But every time i start X-life Deluxe there are no planes showing up and  the airport is just empty.
Also if i want to start atc or gate editor it says "Please turn traffic on before" but traffic is on. If i hit agan the on button i will be asked if i want to shut it down or leave it running.
With FMCar Map everything looks ok an i can let the car drive to every place i want, so there seems to be no issues with the taxi routes.
Could someone please have a look at my file and give me some help what I am doing wrong?
Here is my result (complete Airport with added additional Ramps and Taxiways).
Re: LGKR Xplane 11 Problem
Please upload your log.txt so people can see at least a little bit of what is happening in your setup. Otherwise nobody can even try to help.
Thanks for your answer. Here is the log.txt and a video which shows the problem:
https://www.youtube.com/watch?v=v7R1nMZ … e=youtu.be
I am really interrested in making more airports compatible to xlife.
I gave it another try and created all from scratch, but it don't work. Here are the files. I don't know what i am doing wrong.
X-life is starting up -> no aircraft is showing -> if i press ATC button there is an error message "Please turn on traffic before" -> Button is green and shows that Xlife is running and when press asks if i want to shutdown traffic. WED files are includeed in Airport folder. Is there an option to get more log data out of X-life plugin?
On other airports like LIPH everything works fine so there is no installation issue.
