176
Re: X-Life ver 1.2
Just downloaded x life for my x planes 11 and have a few issues....
1)I installed the blue bell folder (assume this includes the aeroplanes) also have the open scenery x package installed - as I have both installed which one will it use which is best?
2)When I fly near aircraft coming into land (airliners) I notice some of them seem to have small GA aircraft attached/merged with them whats causing this?
3)Notice the airlines I am getting at airports are fictional like air Italy - how can I get real world airlines?
177
Re: X-Life ver 1.2
Totti wrote:
How do you have the folders loaded a screen shot of the folder install would be very helpful.
Hello Brian, "Show parked aircraft" is still unchecked. And the Bluebell XL is in XP11's custom data folder. Or which folder do you mean?
this is in the settings/ on the main screen of overall settings its on the left side of the screen... // I'm not infront of a XP screen so I can't give you a screen shot...
Do you have any Lufthansa etc.?
178
Re: X-Life ver 1.2
Today my flight is ESSA to LEBL.
Xplane 10.51, FS global real weather and sky maxx pro 4
According to flight radar24, departure runway is actually 19 R.
But Xlife only told me to take off runway 26 or 01L/01R
Would it be not possible to have much more choice to choose the right "real" runway ?
Thanks a lot for your improvment
Alexandre
179
Re: X-Life ver 1.2
Alexandre
My experience with XL RWY choice according to wind situation is that it works to 99% !
180
Re: X-Life ver 1.2
Здравствуйте!!! Если есть такая возможность, то хотелось бы получить купон для покупки X-Life Deluxe
181
Re: X-Life ver 1.2
I am at a total loss.  I purchased the x life deluxe through x plane org.  I followed the install instructions up to downloading the new navagraph cycle.   I unzipped it into plugins but it does not show up in the x plane drop down.  The install instructions seem to suggest that it will appear in the plug in drop down and somewhere I need to put a key in.  It just doesn't happen. Any help would be appreciated.
182
Re: X-Life ver 1.2
Got the X life deluxe and follow car apps for x planes 11 and have a few questions:
1)I seem to be able to select the ATIS airport info - but cant hear it - I get get text only how do I turn it on (seem to had it the first time I opened the add on now it just opens text only?)
2)When I speak in the ATC menu I don't hear anything - just when the controller speaks to me?
3)The text on my monitor for the menus such as ATC is almost unreadable (to small) am using a 4k monitor - how can I increase the size?
4)Struggling to get the follow me car to work - how can I call it if I want to be directed to take off runway?
5)Follow me car appears to get micro strutters - how can I get it to drive smoothly?
6)How do I know if I have the latest versions of these 2 apps? (seems to be many different versions)
183 (edited by napelazam 2017-05-31 22:50:50)
Re: X-Life ver 1.2
When I turn X-Life on X-Plane 11 crashes.
How do you even update nav data with fresh cycle?
XL: 0 : JARDesign plugin: C:\Users\omg\Desktop\X-Plane 11\Resources\plugins\X-Life\News/news.txt file updated.
XL: 0 : MessageGreen: X-Life Traffic by JARDesign Ver.1.2 r6 120517
0:03:06.729 I/WIN: Opened window menu bar
0:03:06.729 I/WIN: Opened window Replay overlay
0:03:10.047 E/NET: Download failed with http error: 404 for URL http://www.ftp.ncep.noaa.gov/data/nccf/com/gfs/prod/gfs.2017053118/WAFS_blended_2017053118f06.grib2
0:03:10.087 E/WXR: Download of http://www.ftp.ncep.noaa.gov/data/nccf/com/gfs/prod/gfs.2017053118/WAFS_blended_2017053118f06.grib2 failed with 2:404 (HTTP Error 404 (File Not Found)) at Wed May 31 22:14:42 2017
0:04:08.160 I/ATC: Airport flow changed at EDFE!
CurFlow: Eastern Flow NewFlow: Western Flow
0:04:08.160 I/ATC: Changing EDFE CabState from 0 to 1
0:04:08.160 I/ATC: All departures are done at EDFE. Advancing...
0:04:08.160 I/ATC: Changing EDFE CabState from 1 to 2
0:04:08.160 I/ATC: All arrivals are done at EDFE. Advancing...
0:04:08.160 I/ATC: Changing EDFE CabState from 2 to 0
0:04:08.160 I/ATC: Airport flow changed at EDFN!
CurFlow: AUTOGEN: North NewFlow: AUTOGEN: West
0:04:08.160 I/ATC: Changing EDFN CabState from 0 to 1
0:04:08.160 I/ATC: All departures are done at EDFN. Advancing...
0:04:08.160 I/ATC: Changing EDFN CabState from 1 to 2
0:04:08.160 I/ATC: All arrivals are done at EDFN. Advancing...
0:04:08.160 I/ATC: Changing EDFN CabState from 2 to 0
0:04:08.160 I/ATC: Airport flow changed at LFJL!
0:04:08.160 I/ATC: Changing LFJL CabState from 0 to 1
0:04:08.160 I/ATC: All departures are done at LFJL. Advancing...
0:04:08.160 I/ATC: Changing LFJL CabState from 1 to 2
0:04:08.160 I/ATC: All arrivals are done at LFJL. Advancing...
0:04:08.160 I/ATC: Changing LFJL CabState from 2 to 0
XL: 0 : OpenSceneryXpath find: C:\Users\omg\Desktop\X-Plane 11\/Custom Scenery/OpenSceneryX/
XL: 0 : X-Life NavDataPath =C:\Users\omg\Desktop\X-Plane 11\Resources\plugins\X-Life\navdata/
XL: 0 : X-Life NavDataProcPath =C:\Users\omg\Desktop\X-Plane 11\Resources\plugins\X-Life\navdata/Proc/
XL: 358 : JARDesign plugin: C:\Users\omg\Desktop\X-Plane 11\Resources\plugins\X-Life\Metar/EDFH.TXT file updated.
0:03:10.047 E/NET: Download failed with http error: 404 for URL http://www.ftp.ncep.noaa.gov/data/nccf/ … 8f06.grib2
0:03:10.087 E/WXR: Download of http://www.ftp.ncep.noaa.gov/data/nccf/ … 8f06.grib2 failed with 2:404 (HTTP Error 404 (File Not Found)) at Wed May 31 22:14:42 2017
Is it this?
Or this?
I was not at EDFE. I was at EDFH
184
Re: X-Life ver 1.2
Read
http://jardesign.org/forum/viewtopic.php?id=2652
Is it this?
Or this?
185 (edited by Glider_UK 2017-06-02 11:06:17)
Re: X-Life ver 1.2
http://jardesign.org/forum/img/m/4209/t/p1bhk7594ihf310s01mb310kh4eu3.jpg
What is causing this, another aircraft is pushing it until it gets really close to the runway then it disappears leaving the correct aircraft
This is at takeoff, there is a 737 in the smoke
http://jardesign.org/forum/img/m/4209/t/p1bhk7g8b3fc5ldf1crn1p46po13.jpg
186
Re: X-Life ver 1.2
So, we jump to ver 1.3 http://jardesign.org/forum/viewtopic.php?id=3104
Thanks for your comments!!!
