Topic: FMCar v2.5r1 For Win 7/8/10 MAC OS (X-Plane 11 ready)
FMCar v2.5r1
Whats New:
+ X-Plane 11 compatible
+ Slow initial loading fixed
Now you can add your own custom airport description file like apt.dat file. To do this, Please use "Airports" folder in your ...X-PLANE 10/Resources/plugins/FM/ and put your custom apt.dat file there with NAME.dat filename. As example, you can download EDDL.dat (file for Dusseldorf airport) and put it to ...X-PLANE 10/Resources/plugins/FM/Airports/ folder
If you own an old version of FMCar and not have serial key, please contact support email and just send a copy of conformation email from shop where you get it.
Download here:
http://www.jardesign.org/fmcar/download/FMCar.zip
Re: FMCar v2.5r1 For Win 7/8/10 MAC OS (X-Plane 11 ready)
hi
good morning
i dont know it is happening with me or what. when i call fm car in any airport fm car starts way way a from the aircraft, and it is so small  far away frm the aircraft that it is hard to locate the fm car. respected simmers is any one notice like above
thanking you
Calling FMcar over ATC don't work. I can only order car using the FM map !
THANK U SIR
BUT AM CALLING THE CAR FRM MAP. BUT STILL WAY WAY AHEAD FRM THE AIRCRAFT AND IS TOO SMALL TO LOCATE
THANKS ONCE AGAIN
there is big problem!
the fm car not taking me to where is should be....
its like take me to the main gates .... but not the spesific that i need
soplease fix it hmm
but love all your addons big_smile big_smile
By the way, the FM car does not work with the actual XP11.01b1. Just crashes the complete sim.
But there are other plugins crashing, too. So wait for next release version :-)
LR made changes to the SDK in this release so it is not recommended for end users. In general, I wouldn't recommend using XP11 beta versions from now on, they are intended more for add-on developers...
8 (edited by Sloboda 2017-04-23 17:37:41)
Exactly same here, XPlane CTD after start.
installed the new version for using with X-Plane 11.
In Airport folder I put in the files eddk.txt and eddk.dat
Started X-Plane but I get the message FMCAR not available in EDDK.
Some hints?
Regards,Uwe
Some hints?
Regards,Uwe
Same here, Uwe. Did you find a solution?
That usually means there are errors in the .dat file.
fm car not working on any airport
same problem as Uwek and Totti
after many attempts Igot a hold of Mr romanov and no help at all
he just got mad at me for not being very tech guy
my FM car still not working but they took my money very fast
I did created another ticket 8 days ago but no response yet!!
Update this files inside FM folder to get next version what can read new .xlf file format for ATC taxiroutes.
