Re: JD330 Airliner ver 2.0r1 WIN/MAC 64 bit (X-Plane 11)
obadvw wrote:
Had the same issue that i've faced before in Beta version.
Durring the flight from LCLK to HEBA , After passing RASDA intersection and start the descend as per the TOD mark.
suddenly Found my self on ground in a remote airport not even in the same area, i think airport is E46
attached Log.txt for analysis
This is 2nd time to happen
Obadvw, I had the exact same problem, I also noticed in your log.txt I had the exact same line: "Init dat_p0 type:loc_tak apt:E46 rwy:15"
Which is a closed airport in Texas, dont know what the heck is going on, but 2 flights all of a sudden I am on the ground and cold and dark...
HEy guys.My beacon light is not working.Anybody get the same issue?My a320 works finde.Did a clean reinstall of the aircraft.
Greets
Where can I submit bug reports? I posted 2 days ago here and no response....
Greets
YES,  me too. Beacon Lights not working
105 (edited by GridiroN 2017-05-04 04:34:06)
I found a possible major bug. During a 1000nm/2.5hr flight from KORD to KMIA, the plane's FMC crashed, the spoilers stopped responding a bunch of buttons stop being clickable.
I uploaded the log...reading through it it seems to suggest using the popular 124th ATC plugin is an issue.
https://drive.google.com/file/d/0B8sUzE … sp=sharing
Edit: To be clear, I've been able to reproduce this twice.
X-Plane 11.01 just kill beacons at a330. Sadly. LR will not plan fix this bug. So, I will do this on my side. Until new version of a330, please take this file and put it to Custom Avionics folder instead of old as solution.
107
Hello! I fly with X-plane 11 aktuell ( no Beta) with Mac. A330 2.0 working good. But alltime when Airplane descenting for landing,i am thinking about 25000 feet, X-Plane crash and close! After 10 Hours flying is this Problem Not so funny! What can i do? Greetings from Germany- Klaus
108 (edited by flavio58 2017-05-04 21:48:32)
Works well, thanks.
109 (edited by RC36 2017-05-06 21:05:11)
I'm having the same issue like you guys  3 times in a row.
110
Same issue also for me with both A320 and A330 and same line in the log .....
111
Hi All,
I face to an issue about not enough memory when I want enter ZFW and Calculate landing weight and after that I enter flight plane I have this issue. I did not change my Graphic setting.(one time I reduced graphic setting but this issue did not fix)
How can I fix this issue?
this is my log:
[SASL INFO] "bbox"
[SASL INFO] "bbox"    >>> zulu 20:43:48
[SASL INFO] "bbox"        baro alt=2666 / rad alt=0
[SASL INFO] "bbox"        air spd=0 / gnd spd=0 / mach=0
[SASL INFO] "bbox"        GW=124284 / FOB=10540 / CG=29
[SASL INFO] "bbox"    lat  wait = NAV
[SASL INFO] "bbox"    active wpt = 1
SoundSetPath=C:\X-Plane 11\Aircraft\330_JARDesign\plugins\sound3d\
VolumePath=C:\X-Plane 11\Aircraft\330_JARDesign\plugins\sound3d\volume.txt
3Dsound Engine by JARDesign
2Dsound Engine by JARDesign v.1.0
1Dsound Engine by JARDesign v.1.3
RainTextureID=873
RainTextureID=870
0:06:51.747 I/WIN: Opened window menu bar
0:06:51.747 I/WIN: Opened window Replay overlay
CUSTOM DATAREF (int): jd/diagnost/ghd
Loadsheet!!!
[SASL INFO] "mcdu_fpln"    --> Set active WPT to SBGR for DetectActualWaypoint reason
[SASL INFO] "mcdu_fpln"    --> Set active WPT to RCL for APT_DEP/DEP_RWY reason
[SASL INFO] "bbox"
[SASL INFO] "bbox"    >>> zulu 20:48:37
[SASL INFO] "bbox"        baro alt=2592 / rad alt=1
[SASL INFO] "bbox"        air spd=3 / gnd spd=0 / mach=0
[SASL INFO] "bbox"        GW=208065 / FOB=37993 / CG=27
[SASL INFO] "bbox"    new icao fpln = SBGR SID RCL UL304 ASTOB UM417 MOTVI UM549 MTU UW89 VVC A301 ZIP STAR SKBO
[SASL INFO] "bbox"    new fpln full = 1 SBGR (APT) >>> 2 RCL (NDB) >>> 3 LONAL (WPT) >>> 4 PUKTO (WPT) >>> 5 REPAX (WPT) >>> 6 OBDAM (WPT) >>> 7 ASTOB (WPT) >>> 8 KUGPO (WPT) >>> 9 NEKAM (WPT) >>> 10 ANDIV (WPT) >>> 11 ILTID (WPT) >>> 12 RORIT (WPT) >>> 13 RELUM (WPT) >>> 14 MOTVI (WPT) >>> 15 MANSI (WPT) >>> 16 UBTAS (WPT) >>> 17 DADEL (WPT) >>> 18 VAKOB (WPT) >>> 19 OGTIT (WPT) >>> 20 SIPAK (WPT) >>> 21 PAKEM (WPT) >>> 22 MIMUM (WPT) >>> 23 ILKOD (WPT) >>> 24 EDRAS (WPT) >>> 25 SUDMO (WPT) >>> 26 GAXES (WPT) >>> 27 POPGU (WPT) >>> 28 ROLUT (WPT) >>> 29 MIGOB (WPT) >>> 30 ABIDE (WPT) >>> 31 MTU (VOR) >>> 32 BUTAN (WPT) >>> 33 VVC (VOR) >>> 34 VIDAL (WPT) >>> 35 ANLAV (WPT) >>> 36 EVRAK (WPT) >>> 37 ZIP (VOR) >>> 38 DISC (DISC) >>> 39 SKBO (APT) >>> DIST=2397.5848
[SASL INFO] "mcdu_fpln"    --> Switch active WPT from SBGR to RCL by internal FMS
[SASL INFO] "bbox"    active wpt = 2 RCL
[SASL INFO] "mcdu_fpln"    --> Set active WPT to RCL for DetectActualWaypoint reason
[SASL INFO] "bbox"
[SASL INFO] "bbox"    >>> zulu 20:48:58
[SASL INFO] "bbox"        GW=208064 / FOB=37992 / CG=27
[SASL INFO] "bbox"    new fpln full = 1 SBGR (APT) >>> 2 RCL (NDB) >>> 3 LONAL (WPT) >>> 4 PUKTO (WPT) >>> 5 (T/C) (pseudo) >>> 6 REPAX (WPT) >>> 7 OBDAM (WPT) >>> 8 ASTOB (WPT) >>> 9 KUGPO (WPT) >>> 10 NEKAM (WPT) >>> 11 ANDIV (WPT) >>> 12 ILTID (WPT) >>> 13 RORIT (WPT) >>> 14 RELUM (WPT) >>> 15 MOTVI (WPT) >>> 16 MANSI (WPT) >>> 17 UBTAS (WPT) >>> 18 DADEL (WPT) >>> 19 VAKOB (WPT) >>> 20 OGTIT (WPT) >>> 21 SIPAK (WPT) >>> 22 PAKEM (WPT) >>> 23 MIMUM (WPT) >>> 24 ILKOD (WPT) >>> 25 EDRAS (WPT) >>> 26 SUDMO (WPT) >>> 27 GAXES (WPT) >>> 28 POPGU (WPT) >>> 29 ROLUT (WPT) >>> 30 MIGOB (WPT) >>> 31 ABIDE (WPT) >>> 32 MTU (VOR) >>> 33 BUTAN (WPT) >>> 34 VVC (VOR) >>> 35 VIDAL (WPT) >>> 36 (T/D) (pseudo) >>> 37 ANLAV (WPT) >>> 38 EVRAK (WPT) >>> 39 ZIP (VOR) >>> 40 DISC (DISC) >>> 41 (DECEL) (pseudo) >>> 42 (SPD220) (pseudo) >>> 43 SKBO (APT) >>> DIST=2397.58483
[SASL INFO] "bbox"
[SASL INFO] "bbox"    >>> zulu 20:48:59
[SASL INFO] "bbox"    new fpln full = 1 SBGR (APT) >>> 2 RCL (NDB) >>> 3 LONAL (WPT) >>> 4 PUKTO (WPT) >>> 5 (T/C) (pseudo) >>> 6 REPAX (WPT) >>> 7 OBDAM (WPT) >>> 8 ASTOB (WPT) >>> 9 KUGPO (WPT) >>> 10 NEKAM (WPT) >>> 11 ANDIV (WPT) >>> 12 ILTID (WPT) >>> 13 RORIT (WPT) >>> 14 RELUM (WPT) >>> 15 MOTVI (WPT) >>> 16 MANSI (WPT) >>> 17 UBTAS (WPT) >>> 18 DADEL (WPT) >>> 19 VAKOB (WPT) >>> 20 OGTIT (WPT) >>> 21 SIPAK (WPT) >>> 22 PAKEM (WPT) >>> 23 MIMUM (WPT) >>> 24 ILKOD (WPT) >>> 25 EDRAS (WPT) >>> 26 SUDMO (WPT) >>> 27 GAXES (WPT) >>> 28 POPGU (WPT) >>> 29 ROLUT (WPT) >>> 30 MIGOB (WPT) >>> 31 ABIDE (WPT) >>> 32 MTU (VOR) >>> 33 BUTAN (WPT) >>> 34 VVC (VOR) >>> 35 VIDAL (WPT) >>> 36 (T/D) (pseudo) >>> 37 (SPD220) (pseudo) >>> 38 ANLAV (WPT) >>> 39 EVRAK (WPT) >>> 40 ZIP (VOR) >>> 41 DISC (DISC) >>> 42 (RED250) (pseudo) >>> 43 (LIM) (pseudo) >>> 44 SKBO (APT) >>> DIST=2397.58485
[SASL INFO] "bbox"
[SASL INFO] "bbox"    >>> zulu 21:1:43
[SASL INFO] "bbox"        GW=208028 / FOB=37956 / CG=27
[SASL INFO] "bbox"    new fpln full = 1 SBGR (APT) >>> 2 27R (DEP_RWY) >>> 3 DISC (DISC) >>> 4 RCL (NDB) >>> 5 LONAL (WPT) >>> 6 PUKTO (WPT) >>> 7 (T/C) (pseudo) >>> 8 REPAX (WPT) >>> 9 OBDAM (WPT) >>> 10 ASTOB (WPT) >>> 11 KUGPO (WPT) >>> 12 NEKAM (WPT) >>> 13 ANDIV (WPT) >>> 14 ILTID (WPT) >>> 15 RORIT (WPT) >>> 16 RELUM (WPT) >>> 17 MOTVI (WPT) >>> 18 MANSI (WPT) >>> 19 UBTAS (WPT) >>> 20 DADEL (WPT) >>> 21 VAKOB (WPT) >>> 22 OGTIT (WPT) >>> 23 SIPAK (WPT) >>> 24 PAKEM (WPT) >>> 25 MIMUM (WPT) >>> 26 ILKOD (WPT) >>> 27 EDRAS (WPT) >>> 28 SUDMO (WPT) >>> 29 GAXES (WPT) >>> 30 POPGU (WPT) >>> 31 ROLUT (WPT) >>> 32 MIGOB (WPT) >>> 33 ABIDE (WPT) >>> 34 MTU (VOR) >>> 35 BUTAN (WPT) >>> 36 VVC (VOR) >>> 37 VIDAL (WPT) >>> 38 (T/D) (pseudo) >>> 39 (SPD220) (pseudo) >>> 40 ANLAV (WPT) >>> 41 EVRAK (WPT) >>> 42 ZIP (VOR) >>> 43 DISC (DISC) >>> 44 (RED250) (pseudo) >>> 45 (LIM) (pseudo) >>> 46 SKBO (APT) >>> DIST=2399.54188
[SASL INFO] "bbox"    active wpt = 4 RCL
[SASL ERROR] Error updating avionics: not enough memory
Yoss wrote:
marcelbrietzke wrote:
Hi Euvengy,
on last version A330 2.0r1 speedbrakes DON`T work.
copilot says half / full... - ecam says speed brk, but F/CTL says no speedbrakes and visual the brakes are not out, too. no reducing speed.
it´s very heavy to land the bird with about 200 knots on a short rwy ;-)
please check it
Tested today, i couldn't see or feel your statement, speedbrakes worked like in previous versions.
Check my short Landing!
https://www.youtube.com/watch?v=DzocNnRHv_o
Give it a try after 2-3000miles of flight. They won't work! During short hauls speedbrakes work for me as well, but I usually fly very long flights like SCEL to Hawaii and speedbrake won't work during descent. It can be reproduced anytime.
Same for me on two flights over 6 hours.
Cheers
I7-5820K 4GHZ (OC) | GTX1070 8GB | 32GB DDR4 | 512GB SSD Samsung 950 PRO .M2 x4 | MSI X99S SLI PLUS | WIN10 x64 PRO
"If only I could stop flying toy air planes..."
113
Cheers
Confirm problem sad.
I hear announce about change speedbrackes position, but no correspond indication on flight controls screen, not deployed "physically" and no bracke effect as well.
114 (edited by naigovan 2017-05-10 19:15:54)
Hello! I've noticed strange thing...
I can perfectly start my engines and fly with fuel pumps switched OFF
Did anyone notice such behaviour?
115
Guys , run xplane updater
choose "Update scenery online"
and try same flights that had issues with you
i did the update and downloaded over 10 GB of data, possibly DSF issue on xplane Beta builds.
lets try this fix and see if it works and report back if it works
good luck guys
116 (edited by ilankrt 2017-05-12 22:56:40)
I bet that 90% of the complains are caused by user themselves !! Most events I read shows me that there is a luck of knowledge and mistakes made that can be avoided if - if those simmer will take their time to sit down and read the manuals, look at video tutorials and read article about Airbus planes.
I just ended another test flight with JAR A330 v.3r1. At beginning I had a small problem, then I send over Skype a short question and got after 2 minutes an answer how to fix it. I made a short flight without problems !!!!!  Everything was functioning as it should under the newest XP version 11.01r2.
Nobody is perfect and yes there is at the moment one serious problem. Speedbrakes are deploying during descent for reducing speed. After touch down they didn't deploy. We all know about and surely JAR as well and I am sure that he is working on a solution. But despite this occurrence I can land safely using the thrust reversers.
Before this flight I flew the FF B777 that behaves catastrophic, I flew the A350 that seems to have the most advanced  equipment but not a functional MCDU !! and I flew the B748 that during approach tend to fly in opposite direction to RWY (someone wrote me that he find a solution). People complain and the developer seems to dive in deep silent water - they disappear.
JAR is the only active X-Plane developer that we can talk with and JAR airliner are the best in the XP Sky. So think twice before you send a complain and if you are a beginner learn learn learn and then if you have a real problem come and discuss it with us.....
117
Whilst I would never disagree that people should understand how the plane is supposed to work before complaining about things, everything you have written here is highly delusional. Many experienced simmers have issues with the planes, my previous argument with you illustrated you have, at best a subpar working knowledge as far as the plane and it's representation in the sim goes, and while I like JARs work, and paid good money for it, if you're honestly going to suggest the JarBuses are the best works of flight simulation currently available for XP11, beating out Aerobask, FlightFactor Pro series, Carenado, etc. you're opinion is worth less than the pixels it's written on.
Think twice before you write such a condescending, and ignorant post to a public, forum about the issues facing a paid product.
118 (edited by The3hadow 2017-05-13 16:17:39)
This also happened to me a couple of times now. Out of the last 3 flights I flew in the last days I could only finish one flight properly - very annoying. I posted a thread here because I thought it's a general problem. But it seems it could be a specific one concerning the JD A330.
119
Today same thing happened to me. Right after
TOD going to SBGL I ended up somewhere in
New Mexico I think sitting cold and dark. It was not
an airport. Looked like nothing was around.
XP11 did not crash. This, with air brakes issue
and other bugs...this bird is in the hangar
until JAR can fix it. The thing is I got no other
long rage plane...now what lol.
120
Hello, why can not the a330 after the reach of the flight height the knobs with the right and left maustaste press?
121 (edited by danielRG1198 2017-05-16 16:23:43)
Same thing here flying LEMD-SVMI 9 hours of flight and then suddenly i was in texas!
122
Same here. Alternatively I use to fly an FF A350, it is also a bug bag, but if you are willing to compromise, then - at least - you can fly it smile
I had that issue....it happens when XP stops the sim and gives an error to say scenery is missing or may not look correct. To get around this, go to XP settings and disable messages for missing scenery.
124
version 2.1 posted with a numbers of improvements.
http://jardesign.org/forum/viewtopic.php?id=3056
Please feel free to use support system www.support.jardesign.org and skype j.a.romanov as better way if you have personal issue.
