126
Re: X-Life ver 1.2
Last update of X-plane crashing with x-life, help!!!
Re: X-Life ver 1.2
SandyLee wrote:
Totti wrote:
I have been to EDDH. X-LIFE and Bluebell are installed. But I still can't see Lufthansa aircrafts for example. But many American Aircraft which I have never seen in EDDH. Could anybody tell me the reason for that?
Disable "Show parked aircrafts" in Xplane graphics Settings if you use x-life traffic
How do you have the folders loaded a screen shot of the folder install would be very helpful.
Hello Brian, "Show parked aircraft" is still unchecked. And the Bluebell XL is in XP11's custom data folder. Or which folder do you mean?
128 (edited by max-mueller 2017-04-24 20:19:48)
Re: X-Life ver 1.2
Hello, I have x-life installed, but I have no X-life in the menu bar. What is wrong? Sorry for my english, i am German.
I have X-plane 11.
129 (edited by minpie 2017-04-25 00:44:33)
Re: X-Life ver 1.2
I'm having a tough time trying to update the navdata for X-Life... Everytime I turn traffic on under the plugins menu, it crashes... this is what I see in my log:
XL: 0 : Bluebell XL library find: D:\X-Plane 11\/Custom Data/Bluebell XL/
XL: 0 : X-Life Error: No NavData installed found!
XL: 0 : X-Life NavDataProcPath big_smile:\X-Plane 11\/Custom Data/GNS430/navdata/Proc/
XL: 0 : !!! Error: Cant read file airports.txt
XL: 0 : !!! Error: Cant read Ats file
XL: 10 : X-Life plugin ver.1.2 r3 010317 detect crash.
XL: 10 : Memory dump saved to x-life.dmp file
I am using the latest navigraph airac 1704 cycle. Can somebody please tell me what I'm doing wrong? But everything seems to work fine if I use the default navdata that comes with X-Life.
130 (edited by captbullett 2017-04-25 17:11:35)
Re: X-Life ver 1.2
Havena wrote:
Havena wrote:
my X-Life crashed as well, at least according to my X-Plane log.txt
unfortunately I can not add any files, so what should I do now?
why can't you add files there is a 'Browse' button down at the bottom of the webpage next to the word"Attachments" from there you should navagte to the log.txt file in the XP main folder.
then look for the dump txt also, this will take some getting use to so be pasent and take your time.
I hope this helps you, and after you up-load the files we can work on the next issue.
only when quoting I have it. But anyway, attached the logs.
yes, I was on spring break this is why it has taken so long to get back to you but yes, you have to Quote to have the up-load display...
thank-you for the help.
Re: X-Life ver 1.2
I had a problem with X-Plane, X-Life seems to be linked to this problem.
I linked different files to this message.
Do you have an idea about this problem ?
Many thanks,
Adrien
132
Re: X-Life ver 1.2
I installed X-Life plugin into X-Plane 11 and noticed a dramatic decrease in frame rates, making the simulator unusable with the plugin enabled. Without the plugin I am getting 30-40 fps, with it I'm getting about 10-15 fps.
My CPU is i5 6400, 16 GB RAM, and GTX 1060 with 6GB video RAM.
Can anything be done to improve the performance or is my system too slow to use this plugin?
Thank you.
NM
133
Re: X-Life ver 1.2
Bug Hold Position on X-Life
http://jardesign.org/forum/img/m/3204/t/p1beu11pnc1e0a2841mqvvhf8bp3.jpg.
134
Re: X-Life ver 1.2
By mistake clicked on IMPORT PLAN FROM AIRCRAFT FMS and crashed.
http://jardesign.org/forum/img/m/3204/t/p1beu1emuh1d3v19qi1qn91qlm1fpj3.jpg
Airbus A320NEO JAR 3.0 RC6
135
Re: X-Life ver 1.2
It is not bug of xlife, is a bug of dat file for this airport, you can modify it by using WED
136
Re: X-Life ver 1.2
I just want to know is that any news on real life schedule? It is pretty wired to see many foreign airliner in some small or demostic airport.
137
Re: X-Life ver 1.2
X-Live 1.2r5 published:
+ Cargo stands take in account (if your airport have stands masked as "Cargo" - then cargo aircraft/liveries will use this stands)
+ Add Taxiway drawing for GateEditor (Select GateEditor from Menu and you will see taxilines)
+ some X-Plane 11 bugs fixed (OverWide text drawing, some others)
if you use version 1.2 (any release) - you can update only mac.xpl and win.xpl files
138 (edited by captbullett 2017-04-30 15:29:02)
Re: X-Life ver 1.2
this is in the settings/ on the main screen of overall settings its on the left side of the screen... // I'm not infront of a XP screen so I can't give you a screen shot...
Re: X-Life ver 1.2
Some errors with the new update, for me at least.
This is tested between two approved airports EDDT-ELLX
1. The Aviation table disappears, for no reason.
2. I get a take off RW, but only via "...", from ATC.
3. Some strange errors with SASL.
Attaching the Log.txt
Re: X-Life ver 1.2
[SASL INFO] "bbox"    >>> zulu 5:54:18
[SASL INFO] "bbox"        baro alt=24978 / rad alt=24811
[SASL INFO] "bbox"        air spd=356 / gnd spd=491 / mach=0.84
[SASL INFO] "bbox"        GW=161940 / FOB=11503 / CG=29
[SASL INFO] "ap"    AP diseng. (HiSpdProtection reason)
I see some pilots issues there. Please look at your mach value.
Re: X-Life ver 1.2
Great product...but I have a question regarding cargo aircraft.....specifically BluebelXL ones...How do they know they are cargo aircraft, or have I missed something, as far as I can see there is no aircraft cfg file to edit to tell them that they are.
My cargo aircraft are still not using the cargo gates, even though I have changed them in the gates editor and WED.
Keep up the good work
Andy
142
Re: X-Life ver 1.2
I just bought x-life recently and did some flights. For me the most important issues are these about ATC.
affilyon1 wrote:
Hi Everybody,
X-life have perfect traffic simulation, but from ATC I miss the following features:
1. after takeoff ATC say contact approach, but did not say contact center according FIR, like Frankfurt, Vienna, etc., just when I report TOD, say me contact center and I must say again report TOD.
2. I can't request flight level change in flight.
4. In flight ATC not said me that I change my flight level according semicircular/hemispheric rule to odd or even flight level.
6. ATC does not use real frequencies, why?
Peter
I hope JAR Team can adjust this in the next version.
143
Re: X-Life ver 1.2
awhite717 wrote:
Andy
X-Life scan aircraft types in bluebell folders and mark all F-type aircrafts as cargo and mark Some others aircrafts if they have cargo liveries like Fedex, DHL and so on..
Aircrafts marked as Cargo will use at airport stands marked as Cargo in GateEditor
144
Re: X-Life ver 1.2
affilyon1 wrote:
Hi Everybody,
Peter
Good ideas for future.
About freq - Sure, everyone may set real freq for ATS positions at airport using Gate Editor, and save XXXX.txt file
145
Re: X-Life ver 1.2
JAR wrote:
affilyon1 wrote:
Hi Everybody,
Peter
Thanks JAR, let me suggests one more: Possibility to assign a joy button / key to readback. In certain fases of flight is difficult get the mouse to click in a small button. If I could just confirm ATC mensage with a button will be helpfull.
Feedback:: the traffic interaction is the best we have for XP. The planes really wait when the runway is busy and dont pass over each other. The airport really looks like Life.
Congratulations to Jar Team
146
Re: X-Life ver 1.2
Hello friends,
I`ve a little problem with heavy green lights in the added aircrafts after the plugin start...
Many thanks for your help....
Dosage recommande viagrasansordonnancefr.com avantages des medicaments
Re: X-Life ver 1.2
This problem has not be solved in teh current beta version?
I`ve exactly the same problem with Xlife and heavy green lights
Many thanks for your help!!
simnut wrote:
I have the latest xlife installed with my X-plane 11 and works very well.  Only one problem I have.   I seem to get flashing green lights from some of the AI aircraft as in the pictures below.  They appear to be navigation lights on some of the aircraft.....far removed from the airplane though.  Anyone can tell me what is up? Thanks in advance!
http://imgur.com/a/KJTE3
http://imgur.com/a/Dwkqm
148
Re: X-Life ver 1.2
JAR wrote:
awhite717 wrote:
Andy
Hi again
Thanks for the response.
When you say it scans for F-type aircraft, where is it looking for the "F" is it in the aircraft folder name eg. B74F or elsewhere...If its in the folder name than would be possible to create extra folders in bluebell for B73F and B76F to put all the more specialised cargo liveried aircraft in.
Andy
Re: X-Life ver 1.2
i have problem  with FPS
i have 1080gtx 4krsulotion , i get 60fps (when x-life off)
but when i turn xlife on i get 20fps :S
someone know about it ?
150
Re: X-Life ver 1.2
Why this route doesnt work pls ?
CYYZ SID BMPAH HANKK Q935 PONCT STAR KBOS
I'm trying to insert a PFPX route basically (without the SID and STAR) :
CYYZ KEPTA2 BMPAH DCT HANKK Q935 PONCT JFUND1 KBOS
It just says "BMPAH HANKK Q935 Segment error". But the route is correct. I'm using newest Navigraph data.
