451
About nonworked flightplans - please read Error message at MCDU and lool into log.txt to understand what leg was wrong.
I tried but to no avail.
FP was:
SCEL SID DGO DCT 32S080W 30S090W 26S100W 22S110W 16S120W 06S130W 00N136W DCT WIBIG DCT CAMOS DCT ITO DCT LNY STAR PHNL
Response: CO-RTE ERROR. CHECK LOG
LOG:
[SASL INFO] "mcdu_fpln"    --> Set active WPT to SCEL for DetectActualWaypoint reason
[SASL INFO] "mcdu_fpln"    Error - UNKNOWN POINT TYPE: 32S080W
[SASL INFO] "mcdu_fpln"    CO-ROUTE error occur: ..insert 32S080W
[SASL INFO] "mcdu_fpln"    --> Set active WPT to DGO for APT_DEP/DEP_RWY reason
[SASL INFO] "bbox"
[SASL INFO] "bbox"    >>> zulu 19:34:8
[SASL INFO] "bbox"        baro alt=1678 / rad alt=1
[SASL INFO] "bbox"        air spd=-5 / gnd spd=0 / mach=0
[SASL INFO] "bbox"        GW=140732 / FOB=16447 / CG=26
[SASL INFO] "bbox"    new icao fpln = SCEL SID DGO DCT 32S080W 30S090W 26S100W 22S110W 16S120W 06S130W 00N136W DCT WIBIG DCT CAMOS DCT ITO DCT LNY STAR PHNL
[SASL INFO] "bbox"    new fpln full = 1 SCEL (APT) >>> 2 DGO (VOR) >>> 3 DISC (DISC) >>> 4 PHNL (APT) >>> DIST=5966.8718
[SASL INFO] "mcdu_fpln"    --> Switch active WPT from SCEL to DGO by internal FMS
[SASL INFO] "bbox"    active wpt = 2 DGO
This does not tell me anything special. It found an unknown point type: 32S080W But the AIRAC is 1704 in the plane's FMC and in the PFPX which works from the same AIRAC. So, what should I do?
452
FP was:
LOG:
[SASL INFO] "bbox"
Tried to CLR the points, so I wanted to enter the FP manually. I can't delete DGO. And now I received an error msg saying: WARNING: a330 systems (SASL) plugin error occur. - Please contact support.jardesign.with log.txt file!
So, I attach the log to this post.
453
So.. after a long-long way we jump to release candidate stage here http://jardesign.org/forum/viewtopic.php?id=2907
As you know may be - this is not the end, but just begin, as usual.
I want to say Thank You for all pilots who take part in this long beta-test trip. I read 100% of your issues, sure. I love you!
Not all issues done, but a lot of.. and we will continue..
