201
ScottFDNY wrote:
is anyone else having a problem with altimeter not working when dialing jumps all over the place on the b5 version just downloaded and installed this morning and test flight altimeter not even close to being set. Thanks.
Altimeter or just FCU target altitude knob? With mousewheel or manipulator moving?
202
Error Serial Key when I a will aktivat the plane
203
www.support.jardesign.org please
204 (edited by MichaelMaar 2017-03-08 16:39:40)
I have the same problem - It is impossible to adjust QNH with the mouse wheel. It is really jumping all over the place.
http://jardesign.org/forum/img/m/2599/t/p1bancerl81bcr1avpphnvn1p4a3.jpg
205
Yes, FCU knob, on both settings, with mouse wheel it jumps 15+ mbar and with mouse left right movement, its like 1mm mouse movement, and you are at min or max setting
206
I have the problem too! I cant setup the QNH...
But I have an another problem too.
I get still slower if I have landed and more slowly although no Autobrake is on or I brake.
I can roll only after again I am stopped and lock and undo once the brake.
In addition still a small thing: The Chrono button doesn't work.
Hi JAR,
wouldn't it be time to fix the "Range Selector" knob in efis control panel ?
It's just a little bug in the knob control. On 10NM setting, it makes 2 <click> without moving the knob, and at 160nm
it can't move to 320nm (and if you set "sim/cockpit2/EFIS/map_range" to 7, the knob moves to 320nm and the display
is ok)
208 (edited by VMaximI 2017-03-08 19:18:13)
I also have problems with the altimeter
Ребята (разработчики) здесь можно баги по-русски описывть? А то с инглишем туго у меня.
OS Win7,  Intel Core i5-6500 3.20GHz, DDR4 16GB 2133MHz, nVidia GTX-970 4096 MB, XP11v.pb13, A320v.3.0b4, Python Interface, XP NOAA Weather v2.4.4, XPUIPC, BLU-fx, EFASS XPSM, FlyWithLua.
209
With the last version (V3 b5) fuel truck has strange lights .
On the top two large yellow squares and below red lights are large squares also ...
For me this did not exist before .
With new version (V3b5) it's impossible to set QNH .
Or you reach 850 or 1190 ...
The same here.
Dieter
212
Great work JARDesign! big_smile
213
Same problem here with b5 and altimeter stuck. Current version not flyable. Thanks.
214 (edited by zKENTz 2017-03-09 13:21:13)
Help me pliz! Why in the x-plane 10 green textures in the cabin. Show your finger where you want to poke to solve this problem.
215
Did you use mousewheel whan you over it?
216
WoW! you can contact me skype - will try to check this
217
Ok, need time to fix this. I hope short time.
218
Hi, uncheck the "show clickable areas in cockpit", in the Xplane's settings.
219
Please test solution for BARO knob. Need replace this file at "/a320/Custom Avionics/" folder.
If work well, not need install beta 6 - it is the same beta 5 with this new file
220
It's working fine, thank you boss!
221
Working great here too.
Lee
222
Works now.
Thanks a lot.
223 (edited by ilankrt 2017-03-10 11:04:48)
Test flight A320 b5, ULLI - UUEE
1. Very annoying is the new (?!) reflexion of the sun light (I think because of the low sun position in the north hemisphere) on the instrument panel, so it is not possible to read data !
2. The reflexion of instruments and seat cover in the pilot windows is also too egregious and really disturbing during flight - see image
3. Knob story seems now to have an end
4. Calling FM car for taxi don't work, I have to do it over the FM map...
images: Disturbing Light and reflection
http://jardesign.org/forum/img/m/1591/t/p1bartva1vf3n4r61mvfddu17jf3.jpg
http://jardesign.org/forum/img/m/1591/t/p1baru00nv1pus13ef1d3q7p8b346.jpg
http://jardesign.org/forum/img/m/1591/t/p1baru0jjv1evo1vm4301sc8ijg9.jpg
http://jardesign.org/forum/img/m/1591/t/p1baru1fomj94b7t1lde1h4117ssc.jpg
http://jardesign.org/forum/img/m/1591/t/p1baru3cg8oar17pn136e1iclkbf.jpg
224
Looks realistic to me... Love the reflections. Thanks team.
225 (edited by MichaelMaar 2017-03-10 15:45:22)
Landing at EKAH Aarhus Denmark...
I need to have confirmed this. On ILS glide slope I'm off the centerline by 20 meters to the left, and the ILS dimond does not center ither (see picture:
http://jardesign.org/forum/img/m/2599/t/p1basajrhq3ltmcf1m9c1ke7148u3.jpg
When actually landing the plane banks to the right at the last moment (see picture):
http://jardesign.org/forum/img/m/2599/t/p1basak68t1gv2dp2r901k53a4i5.jpg
Is this a bug in the A320 or is it X-Plane 11 (LR) or is it the navdate (I'm running 1703)?
Just added video clip: https://youtu.be/k73onltpyno
/Michael
