176
adam_dk wrote:
hello dear I'm new user for x plane 11
and I would like to buy this aircraft but in x plane store said its only for x plane 10 any advice plz
Org store send you a key that you can use to activate beta version posted here until final release
177 (edited by ilankrt 2017-02-28 18:09:42)
Test flights A320 v.b4. XP11, XL, BSS 3.1, SMPv4.0-2.1, RWC 1.1
KLAS - KLAX no crash. (last XP11 crash maybe due to the use of FMC on my iPad - need to check)
1. hPA knob: At first wrong direction, then after set it works correct - very wired!!
2. X-Life setting table (see image)
3. stairs car for rear door left above ground (see image)
4. Wrong SID: Instead to south direction XL offers SID to north.
Question to JAR: at what altitude and speed the speed brakes can be deployed ?
http://jardesign.org/forum/img/m/1591/t/p1ba2uj5h63di6eu1c2k1afnr53.jpg
http://jardesign.org/forum/img/m/1591/t/p1ba2uj5h61pcp1moj1hlc1bgt44p4.jpg
178
A/THR is not working under certain conditions.
Can be easy verified:
1) Hot Start.
2) Take off, set height=10000, speed=250, A/THR=on, AP1=ON
3) Wait until plane stabilizes at 10000 ft/250kts.
4) Set height=2000ft.
5) wait until plane begins to sink.
6) switch off AP1 (move joystick)
Regardless what you are doing, A/THR keeps engines at IDLE.
Switching off/on A/THR does not help !
what helps is sinking to 2000ft.
Now A/THR is working again holding 250kts.
Best regards !
179
Hello everyone. Some cockpit interior lights do not work, for example those on the side tables. Any ideas?
180
Just tried with XP11pb13 and nothing seem to have changed.
I still get some sound errors:
SoundSetPath=X:\X-Plane 11\Aircraft\JARDesign\320_JARDesign\plugins\sound3d\
Sound3d:OAL Wrong sound format  X:\X-Plane 11\Aircraft\JARDesign\320_JARDesign\plugins\sound3d\flctrl/flapturb.wav
Sound 3d Load file error for - X:\X-Plane 11\Aircraft\JARDesign\320_JARDesign\plugins\sound3d\flctrl/flapturb.wav
VolumePath=X:\X-Plane 11\Aircraft\JARDesign\320_JARDesign\plugins\sound3d\volume.txt
and some SASL errors (a lot):
[SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
I also see some short red SASL error messages in the sim when entering flightplan (something about "contact the developer")
And I could not get it to catch GS - again (had to land manually).
So all in all - the new XP11pb13 did not have any effect at all.
""Happy coding :-)
/Michael
181
I have notice some instability to SASL affecting the Sound especially BSS sound.  Speaking of the BSS sound, the Flap sound is incorrect.
The second thing I've noticed, is the FMS don't always follow the flight plan.  There seems to be at least a waypoint that it does not follow and must use DIR button to re-direct to the next waypoint.  I've noticed the same with A330 as well.
That's my input.
182 (edited by flightime56 2017-03-03 03:37:48)
Nothing in sound system was changed, as i remember
With the latest BSS, I don't feel there is any difference in the sounds between the cockpit and the far back of the cabin? The sounds are not as deep as they were originally?
original Sound3d file is out of plugins folder and replaced by BSS sound3d-1 package?  SD
183
Yesterday i had the problem that the QNH light in PDF starts and stops blinking (after some seconds) from itself.
I was >10000 feet high, so there was no cause for this....
Hello, the cabin is dark at night and I can't switch the lights for the Pax on. Any help for my passengers?
185
BSS will provide a new version of their soundpack wich will update the pitch/volume/and so on for xp11 and 10
(stated on their facebook page)
Maybe your problems may get solved with it
BR
186
Atkins90 wrote:
Hey everyone, Anybody having this issue?
Deleted the previous 320_JARDesign folder in the X-Plane 11\Aircraft folder and put a the fresh xp11 320_JARDesign in the aircraft folder and this appears in the bottom left of the screen.
I enter my serial and nothing happens.
The xp10 versions worked fine but I was having the engines not starting up problem and this update seems to fix this.
For the record, I bought my copy recently so it should work.
Thanks guys!!
http://jardesign.org/forum/img/m/4074/t/p1b9tnu904uh0vdm2a61sht192r3.jpg
It says:
ERROR: a320 systems (SASL) plugin not activated.
- Please check your aircraft installation!
- Please check what your aircraft was activated!
- If activation window not appear  - please contact support
I have the exact same issue! I did not find a solution yet! Has someone an idea how this can be solved?
187
The lights will turn on automatically after you reach your cruising altitude. This however requires HDR enabled. In X-Plane 11 it is not anymore separated checkbox but instead move Visual Effects slider of the graphics settings to the right until you see High(HDR).
188
Got a new bug, reproducable:
1) Load the plane
2) Press "Hot start"
3) wait
4) press the "HDG/TRK" Button (Flight Director Mode switch)
5) Don't touch anything....
The gren Marker is jumping around horizontally, randomly. Even through the MFD :-)
http://jardesign.org/forum/img/m/552/t/p1bacd6ac618ptd6n1eul5c9u7i3.jpg
http://jardesign.org/forum/img/m/552/t/p1bacd6ac6ebum7m1q6h1eeak884.jpg
http://jardesign.org/forum/img/m/552/t/p1bacd6ac6aho6el1a3g1fca11875.jpg
http://jardesign.org/forum/img/m/552/t/p1bacd6ac6ecjbp17dt10i01ilb6.jpg
http://jardesign.org/forum/img/m/552/t/p1bacd6ac6ogr692rktq18kdj7.jpg
http://jardesign.org/forum/img/m/552/t/p1bacd6ac6bn310al18mftvdv438.jpg
http://jardesign.org/forum/img/m/552/t/p1bacd6ac66dmiqeggukvk19nk9.jpg
Again and again same appeal: You want to help or get advice
give us information about your system configuration and software versions.
Write them once in you personal editor.
Is it so hard to understand?!
190
Does anybody have any issues with the Cruise Level? It doesn't let me set it above FL230 in the MCDU once I enter the block fuel and once I select a SID it doesn't let me above FL170?
191 (edited by Luca 2017-03-04 20:04:59)
I found out what caused my problems (SASL Error and BSS Soundfile Errors in Xplane 11 Logfile).
I changed the Callsign in a320neo.acf and apparently the SASL anti piracy protection checks the file for its validity.
So... i have overwritten the file from the original ZIP package and voila... everything is working again...
Somehow sad, would be nice to be called somethign different then "A320".
PC - Windows 10 x64 - 16GB RAM - i7 3770k - Gigabyte GTX 980 Ti - Xplane 10.5.1 - X-Plane 11 (recent beta) - Recent NVIDIA Drivers
BSS Soundpack - Landing Plugin - EFASS Plugin
192
After finishing the flight, I can´t get the chucks and the gpu anymore. Why?
iMac 27" End 2013, 3,5 Intel i7, 32GB DDR3, GTX780M 4096MB, Mojave 10.14.3
X-Plane 11.32, A320 latest and A330 latest
193
They don't appear after pushing the park button on left side menu?
194
Configming this, I cannot set fL above FL270 aDN plne calcultes wrong T/D
195
The "Park" underneath the Menubar isn´t there anymore but in the securing-checklist it is named to put chucks on.
The gpu is in the menubar but can´t be engaged after the flight. You have to Start x-plane again to get it working.
196 (edited by jslickjr 2017-03-07 19:16:06)
Try engaging the parking brake. "Park" should then be available in the menu as well as the GPU.
197
Ok.. as you may be know, Laminars finish engine tuning inside XP11 and offer retune their engines for all developers to get adequate N1, Thrust, performanse and fuel burn.
So - beta 5 as result. I hope this is last huge changes in XP11 and we can just work on minor details to reach release.
198
Thank You Eugeny, will try this evening after work.
199
going to test b5 as soon as possible. Thanks JAR
200
is anyone else having a problem with altimeter not working when dialing jumps all over the place on the b5 version just downloaded and installed this morning and test flight altimeter not even close to being set. Thanks.
