151 (edited by Yelmo 2017-02-27 09:40:22)
I had a few problems with the latest beta4:
The VNAV stopped working during take off. (the guide stop dissapear from the screens) I managed to make it work again turned in on/off the altitude knob -because the guide appeared again-, but it was actually not working as I flew over the limit altitude I set up. Then when I wanted to modify the altitude I couldn't move the knob at all. I tried several times to push/pull the knob and at one point the whole FMS crashed and I lost the flight-plan.
I also lost the mouse indicators just before take off, although the dials and knobs were still working. They just dissapeared on mouse hover.
152
hdespres wrote:
petr.yaroshevich wrote:
Franz007 wrote:
I'm having problems with the BSS-soundpack. I can't hear the sound of the engines...using the last beta 4. Is it possible that the soundpack doesn't work with betas?
I confirm that after copied the folder "sound3d-1" (BSS 3.1) in the folder "A320_JARDesign/plugins" sounds are played incorrectly, and the engine sound is also not hear.
Did you remove the sound3d folder?
Oh no...i did not! Thanks, will try again.
153
Strange bug on the windows.
154
I cant Activate my AC. When the Activation screen comes up, I enter the 26 character license key which I received from My Commerce when I purchased 2 years ago. When I hit enter it says there was an error activating.
So then I try "Get Activation Code." It asks for my serial #, I enter the same code as above and it gives me a Activation code. I assume the next step would be to hit the "Next" radio button, but when I do, nothing happens.
Any help would be appreciated.
155 (edited by Atkins90 2017-02-26 17:41:21)
Hey everyone, Anybody having this issue?
Deleted the previous 320_JARDesign folder in the X-Plane 11\Aircraft folder and put a the fresh xp11 320_JARDesign in the aircraft folder and this appears in the bottom left of the screen.
I enter my serial and nothing happens.
The xp10 versions worked fine but I was having the engines not starting up problem and this update seems to fix this.
For the record, I bought my copy recently so it should work.
Thanks guys!!
http://jardesign.org/forum/img/m/4074/t/p1b9tnu904uh0vdm2a61sht192r3.jpg
It says:
ERROR: a320 systems (SASL) plugin not activated.
- Please check your aircraft installation!
- Please check what your aircraft was activated!
- If activation window not appear  - please contact support
156
Sorry but this beta is only for xp11
157
Oh sorry, Im using 11!
I meant the xp10 versions of a320 worked until the latest xp11 beta came out then the engines stopped working. So I downloaded this release for xp11 and I have the following error above!
Many thanks.
158
Very strange...still no sound of the engines when sitting in the cockpit. I can only hear the engines when i go very close of the engines with the cam. Tried to put the sound to max, doesn't work...
159
Hi guys
So I see the version for xp 10, is dead? Many of us have bought this version to see that there is no movement
160
Test Flight KLAX - KLAS, A320 b4, XP11, BSS 3.1, SMPv4.0-2.1, RWC 1.1
Perfect flight under XL ATC !  I hope to get same results in the coming test flights.
BTW one can say I am rude, but the ongoing jabbering instead of beta test reports is annoying !
161
A320ver3.0 beta 4 does not accompany the flight plan until landing. Reaching 30mil, does not follow the most
162
Question: has anyone that use an iMac same configuration like mine installed OSX Sierra running XP11 and JAR A320/A330?
163
1 How did you installed your FP?
2 Did you made the flight under XL ATC?
3 Do you use AIRAC Cycle 1702
4 Did you installed GNS430 folder in "custom Data" folder?
164 (edited by Luca 2017-03-04 19:51:32)
Hi there,
today, out of a sudden, i get a SASL plugin error. All A320 Side menu buttons are visible and the LOG file says:
SoundSetPath=D:\X-Plane 11\X-Plane 11\Aircraft\320_JARDesign\plugins\sound3d-1\
error: mv_DRF == NULLjd/snd/n1_gs_l
error: mv_DRF == NULLjd/snd/n1_gs_r
Sound3d:OAL Wrong sound format  D:\X-Plane 11\X-Plane 11\Aircraft\320_JARDesign\plugins\sound3d-1\flctrl/flapturb.wav
Sound 3d Load file error for - D:\X-Plane 11\X-Plane 11\Aircraft\320_JARDesign\plugins\sound3d-1\flctrl/flapturb.wav
VolumePath=D:\X-Plane 11\X-Plane 11\Aircraft\320_JARDesign\plugins\sound3d-1\volume.txt
3Dsound Engine by JARDesign
a bit more down it says:
!!!! DO EXIT disable
JARDesign 3D Sound Engine Disable
!!!! DO EXIT stop
0:03:38.097 I/ACF: Loading airplane number 0 with Aircraft/Laminar Research/Baron B58/Baron_58.acf
0:03:38.482 D/SOUN: soun_bank dtor is unloading sound bank 000002BE493E2BB0/0000000000200C00:Aircraft/Laminar Research/Cessna 172SP/fmod/Master Bank.bank
0:03:38.482 D/SOUN: soun_bank dtor is unloading sound bank 000002BCCF437630/0000000000200100:Resources/sounds/Master Bank.bank
Fetching plugins for D:\X-Plane 11/X-Plane 11/Aircraft/Laminar Research/Baron B58/plugins
Loaded: D:\X-Plane 11/X-Plane 11/Aircraft/Laminar Research/Baron B58/plugins/xlua/64/win.xpl (com.x-plane.xlua.1.0.0b1).
0:03:38.482 E/SOUN: Could not load sound bank at: D:\X-Plane 11/X-Plane 11/Aircraft/Laminar Research/Baron B58/fmod/Master Bank.bank FMOD Error: 18
I reinstalled the BSS soundpack. Until yesterday night, everything worked just perfectly. I didnt change anything in my computer between flights.
Strange, after deleting the sound folder, the error persists... and... whatever is wrong, it looks funny....
http://jardesign.org/forum/img/m/3032/t/p1b9vqra8bhp31pqb1kd31g2ice73.jpg
EDIT:
I found out what caused my problems (SASL Error and BSS Soundfile Errors in Xplane 11 Logfile).
I changed the Callsign in a320neo.acf and apparently the SASL anti piracy protection checks the files for their vailidty.
So... i have overwritten the file from the original ZIP package and voila... everything is working again...
Somehow sad, would be nice to be called somethign different then "A320".
PC - Windows 10 x64 - 16GB RAM - i7 3770k - Gigabyte GTX 980 Ti - Xplane 10.5.1 - X-Plane 11 (recent beta) - Recent NVIDIA Drivers
BSS Soundpack - Landing Plugin - EFASS Plugin
165 (edited by ilankrt 2017-02-27 16:14:51)
2 Test flights A320 v.b4. XP11, XL, BSS 3.1, SMPv4.0-2.1, RWC 1.1
First flight until TO all functioning well. After take-off rotation I saw bird passing and then the 2 engines died.
This was an ״amazing crash" :-)
Second flight, TO, TC, Cruising, with no occurrences. After TD at descent begin suddenly crash. --=={This application has crashed!}==--
166
Are you sure it's the right attached file ?
I made a few test flights since yesterday XP11pb12 A320-3b4 (EKCH - EKAH) and (EKAH - EKCH). It is a short trip (25 min) and I have done this flight a lot all the way down since XP 10.50.
I do not expect any fast fix (will wait for some good solid programming - it's better that way).
I have experiencing the following.
1. BBS 3DSound - not all sound is as last week (XP11pb10). It seem that something is missing.
2. I have a hard time getting the FMS to work. It seem to get entered commands OK, and it is following the flight plan OK. But I always have that feeling (something is not right.
3. At final approach it is hard to make it catch the GS. and if it does - it have some difficulty aligning horizontally to center line (If I get it to track I seem to end up with 10 to 15 meter to the left of the center line every time. But what ever - I get a lot of practice landing manually.
As said - do not jump to the keys trying to make a fast fix - That have never been a good idea - I'm a programmer my self.
/Michael
168
Please change the FOV to what it was before..
169
Is transponder screen bugged? I can't switch on screen
170
Hi Eugeny and all.
I tried a flight KSFO - KSAN. SASL warning!! I attach log.txt a320 3.0b4. It seems mcdu issue... Xplane 11 pb12.
Cheers from Spain.
171
Thank you Jar for your quick fixes.
Not having to wait for the X-Plane RC for you to upgrade is much appreciated.
XP 11b12 and a320 3.0b4.
Having great flights, hope the next beta doesn't upset your previous fixes.
172 (edited by ilankrt 2017-02-28 17:22:12)
For all beta tester that don't like the narrow captain default view:
I changed the perspective to include all AP buttons in version b4.
If you want it, all you have to do is to exchange the original "a320neo.acf" file
to the attached file.  (keep your original file...)
Note:
1 I changed parameter to put view exact in the middle of the captain chair. (new .acf file)
2  this is valid only for version b4, but it can be easily done for every further version.
I intend to do this unless JAR will take this change into account.
http://jardesign.org/forum/img/m/1591/t/p1ba2ap1t3cb0o17td7k2c1v7d3.jpg
173
WoDi wrote:
b4
SASL error: [SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
Edit: A new flight plan and the error was gone.
If you have this stable - please contact me skype j.a.romanov - will try to get this on my side
I have the exact same problem. When trying to 'TMPY F-PLN' after choosing SIDS and NO TRANS.
I reload A/C, redo it and the same.
"[SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value"
Flight from EHAM to EHGR when choosing RNW 24 then AND1SY NO TRANS and TMPY F-PLN and get the error. I did it 4 time and got same error each time
174
Solved deleting all files inside preferences folder
175
hello dear I'm new user for x plane 11
and I would like to buy this aircraft but in x plane store said its only for x plane 10 any advice plz
