126
WoDi wrote:
b4
SASL error: [SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
Edit: A new flightplan and the error was gone.
If you have this stable - please contact me skype j.a.romanov - will try to get this on my side
XP11beta12 issue fixed. Please redownload a320 to get beta4
Thanks!!
Just a short question: In which file are stored the customised views in order to save/restore them between re-installations of the a320?
cheers
XP11 beta 13,  A320 3b4, Windows 10, GTX 1070, Intel Core i5-6600K @ 4.3GHz
128
a320neo_prefs.txt may be
Hello
Thanks for your update and fix proposal. After downloading the latest version beta 4, still engines do not start.
Now, the version number in the cockpit refers to V3.0B2 ! do I miss the right link ? Tried a couple of time to re-load and re-install...
130
I would like to say "Thank you, for this fast service!" Now I am thinking about to buy the sound packs for my 320 and 330. Are they compatible or should I wait? Best regards Thorsten
Hi Eugeny,
At nighttime one cannot read the figures on the  ATC-Buttons because they aren´t lit. Could you change this.
iMac 27" End 2013, 3,5 Intel i7, 32GB DDR3, GTX780M 4096MB, Mojave 10.14.3
X-Plane 11.32, A320 latest and A330 latest
132
andrea.motta wrote:
Hello
i have A320JD V3.0B4 using this link
133
So far so good with B4.
I'd like to point out that the QNH knob seems to be working in "reverse scrolling".
134 (edited by w_pienaar 2017-02-25 17:00:57)
Updated to B4 earlier today.
The rudder trim is stuck at 10deg Right and I'm unable to zero it - The rudder trim knob turns but has no effect.. Is this a known issue?
P.S. I had a similar issue with a previous flight but U was then able to zero it and after a few minuted it automatically returned to 10 Right again. The process kept on re-occurring.
Will
135
The Bus is working great so far - is there any way to see the camera shake effect? Even though it is switched on, I cannot see any effect (with or without Cinema verite). Thank you.
136
I downloaded B4 and still cant start engines and even if I let XP11 start them, only engine 2 starts; engine 1 does not Anyone else with this problem?
137
I am finding that the VSI does not work in this latest update.
Also is the fuel flow correct?
EDDM - EGLL 2:30 4 hrs fuel on board, empty crossing the French coast.
XP11b12 - A320neo v3.0b4
No issues! Flew EDDH - EGCC from cold to shutdown...
SID/STAR needed editing but otherwise fine, no airbrake up issue, ILS Align and activation fine, perfect engine shutdown....  perfect flight.
I am not crazy about the external lighting (landing, taxi lights) too big and blobby for me...
http://jardesign.org/forum/img/m/30/t/p1b9t29s8qokd1t4sq441fb6slq3.jpg
Looks great in XP11!
139 (edited by Franz007 2017-02-26 12:16:05)
I'm having problems with the BSS-soundpack. I can't hear the sound of the engines...using the last beta 4. Is it possible that the soundpack doesn't work with betas?
Nothing in sound system was changed, as i remember
Works here in both A320 and A330 betas with XP Beta12
142
I confirm that after copied the folder "sound3d-1" (BSS 3.1) in the folder "A320_JARDesign/plugins" sounds are played incorrectly, and the engine sound is also not hear.
143 (edited by lanmancz 2017-02-26 13:54:10)
thanks for the XP11 update for this nice plane. I just made a couple of quick flights so far and it works fine for the most part, I only noticed 2 things really :
- the engines are still a bit wonky probably due to the new engine model, the left engine even shut down on me a couple of times during taxi when I retracted the throttle to idle, then it automatically restarted.
- and (probably related to the engines) the autopilot can also do weird things. I noticed that during later stages of my descent when my speed was around 210 kts with flaps1 extended the autopilot could not keep the descent rate steady. It kept wobbling up and down, overshooting the target speed and the oscillations kept building up to the point I had to take full manual control to stabilize it.
anyway, I realize it's a beta of both products so it's not a complaint, just fyi. Looking forward to further updates! Thanks.
edit: oh and one more thing - some of the cockpit labels (the radio selectors and transponder number pad for example) are invisible during night
edit2: btw are there any plans to extend the cockpit functionality so both sides are independent please (like radios, MFDs etc) ? That's imho the last thing to make this plane really great.
144 (edited by hdespres 2017-02-26 13:33:06)
Did you remove the sound3d folder?
145
Thank you, after deleting the folder 3dsound, the soundpack began to work
146
You're welcome.
I can not add on PD bearing distance waypoint. is it not possible yet?
148
Look, the datarefs have changed for this button.
The ALT-PULL-Button makes problems. You can pull it with the mouse (optical in the cockpit),  but if you put a joystick-button or a key-command on it, nothing happens. If you take the mouse, the joystick-button or a key-command the dataref in the DataRefTool doesn't switch from 0 to 1 and it doesn't change its colour.
150
Hi, What vcredist_x64 to work A320 NEO ?
