Thnx. This worked! Tried Air Canada livery and it worked too. Strange, Air Canada from JAR forum did not work.
"If only I could stop flying toy air planes..."
JARDesign Group Board → Beta-versions (Download & Discussions) → ver.3.0 beta 2,3,4,5,6,7 for X-Plane 11
Your welcome - sometimes it takes a pc restart been noticing that with XP
First attempt with XP beta version on XP11pb11.
Few issues:
- Liveries downloaded from JAR forum do not switch; thumbs do not generate correctly. Generated thumbs placed in the livery folders are the same stock A320 Neo livery. Seems aircraft does not "see" liveries folders, except Lufthansa it came with, : D:\X-Plane 11\Aircraft\320_JARDesign\liveries. I have two other 3rd party airplanes, CRJ 200 and Epic 1000 v.2, both switch liveries and generated thumbs OK.
- Parking brake release will disconnect and remove ground power and remove fuel truck; aircraft will go cold and dark if was powered up
- If parking brake was released before connecting ground power and/or calling the fuel truck it is no longer possible to connect the ground power or call the fuel truck; other options like doors, stairs are working
- Switching airport while A320 is loaded will remove parking brake when aircraft loads at the new airport, thereby making it impossible to call the ground power or the fuel truck
- XP11 weight/balance/fuel menu shows single fuel tank
Log attached.
PB should be On if you wanna call any ground stuff
You cant manage fuel via XP menu, there is real-like fuel management using fuel truck widjet
Can't go TOGA with ATHR on. Can't limit thrust either, unless set it all the way down to idle.
https://youtu.be/-z4q64cnP40
Please describe what wrong and why (link to docs will be useful) you think this.
The Loud Speaker button does not work properly. The button only works as Mute or Maximum. The button does not rotate in the intermediate values.
Yes, it can work as MUTE only
when I save and load a situation, the flight plane nor the plane settings are saved or restored. It works fine on the stock planes. Is that a known issue?cheers
This XP10/11 function cant work here, cause it cant remember 1100+ custom datarefs and save state of thousands internal variables.
sultan.of.swing wrote:Bought mine OCT 16 and according to the serial key updater I have to pay.
My serial is rejected too. I ve bought my copy of a320neo on 11.11. I dropped a ticket. No replay yet.
Check your spambox if you get no answer within 12 hr. Sure, you can contact via skype j.a.romanov if need.
I paid for the update yesterday and still have no email response. Paid through PayPal.
JeffG
This is not good.
You can contact me direct via skype j.a.romanov or www.support.jardesign.org
Looking at throttle input vs actual performance...
should they not be equal ie: 25% throttle equals 25% RPM?
Please see video...A320 v3 b2 video: https://www.youtube.com/watch?v=Pr49vBJ5gkc
The A330 b6 seems to perform properly - see video below.
https://www.youtube.com/watch?v=OwVM84c9po8
Hope this helps.
Engines perf problems happen after LR "tune" internal engines modules. We will fix this just after XP11 release, not before. When we will get final engines in XP11.
So far so good Eugeny , Looks good
The size of the icons created is wrong , A320 is the only aircraft doing it ,
And please add Aircraft Class , Design Studio and manufacturer to acf ..
P acf/_manufacturer Airbus
P acf/_is_airliner 1
acf/_studio JARDESIGNRegards
Lawrence
done this for new beta 3 (work on it now)
Awesome! Thanks for update, got my serial quick too.
BSS 3.1 did not crash on me yet, works fine so far.
Some things:
ECAM Buttons are black, cant see them at all unless they are selected.
Red overspeed tape does not work at high altitudes
Overspeed warning does not go away even if you slow down
Yes, will check overspeed tape. Thanks!
Ok, dear pilots! Thanks for your reports, i read all of them 100%. We work on next beta now.
First off luv this Product - well done
Curious why does this green ring portion on engines is not there in XP11 version - it appears now as solid metal even though its shown on the image file to be used but not in actual sim thanks
Test flight KATL-KMIA crash after landing.
log.txt file shows wired long list of errors all the way long, but preparation, start, take-off and flight proceed without any problem.
during landing I didn't confirm "ready for landing". After landing I tried to continue sequence on XL and then XP crashed....
Can't get it activated at all. Shows problem with SASL plugin (not even on the list of plugins but the plugin files are all in their place), the activation window doesn't show up...
Hi Guys can I update to navdatapro 1613 if I buy it from aerosoft - will it work or should I wait till A320 is out of beta ? current data that comes with A320 is very old - not sure if I have to use the old navdata until the dust settles - thanks
I use Airac 1702 without any problem .
I think you can update with the one you want .
Is this only for XP 11 or will it also work for XP10
I am not sure this question follows my answer ... if so I confirm the use of Airac does not depend on XP10 or XP11 .
You can update the one you want .
Thank you ![]()
Hi - I've been holding off buying the JAR A320 until most of the XP11 bugs get sorted (Im not that way inclined to Beta test things) anyhow, I just watched aerosimgaming on Twitch flying the latest xp11 update ver. V3.OB2 and all seemed fine and without any real bugs. So I went and bought the A320.
Got the latest update and installed - Only to find, on my system the plane doesn't follow the flight plan (FD is on), if I go heading select and change heading, does nothing, speed select is either full throttle or nothing...
Any help would be much appreciated - Oh BTW - I also have the A330 JAR - its the same as above.
Is there something in XP11 I need to switch ON/OFF?
WiReLaD - AKA Mike
You seem to be having problems with both A320 and A330 which are running ok on my system. Maybe it's a MCDU procedure error on your part. The airbus certainly doesn't operate like the Boeing stuff. Maybe look at some complete youtube flights as you may be missing something. Hope this helps.. happy landings.
X-Plane11b11 : A320 v3.0b2
Did three flights... YBBN - YBCS and return.
Issues encountered.
Engines still don't shutdown AFTER flight? If you do a startup and shutdown on the ramp it works, but not after a flight?
Flight profile on upper ECAM is not over covering the engine data image.
ILS does not Align? with horizontal diamond and the vertical diamond does not move either? (tried at both airports and both failed) It does capture the ILS vertical slope, but the vertical diamond does not move? So the aircraft does not centerline adjust while in the horizontal beam with APP on.
... I understand this item is also a LR issue? But I don't get this on other aircraft in XP11?
Really annoying "airbrake" activation for no reason, the airbrake will activate one stop up constantly while flying?
Cockpit overhead lighting is always on? You can't make the cockpit dark for night landings as the main overhead lighting is always on, switching the panel to "dark mode" doesn't work either?
Cabin lighting looks nice but more (adjustable?) lighting needed around the cabin... Nice job though, seat back screens would be nice with an image and above panel would be nice with a lit no smoking sign but overall it is too dark back there, and I think the Business class seats are too dark and look older than they actually are, need a lighter tan...
Thanks Stephen
X-PlaneReviews
Jar, any chance of reinstating the 2nd push on the ND Terrain button to get the taxi/runway display ?
Enjoying the new version thanks
Beta 3 is posted
beta 3:
+ reflection maps for external 3d improved (thanks Rashid)
+ ECAM buttons light bug fixed
+ brake and clock night lighting (front panel) fixed
+ baro selector work fixed
+ fcu knobs work improved (mousewheel selection work both for classic/comfort manipulators style) - please use MCDU Menu page 2 to switch style
+ not-transparent in-cockpit sunglasses fixed
+ some minor bugs fixed
About engines N1 issue - we expect what this will be much better in XP11pb12
